Play Shadow PC on PineBook Pro
Obviously no one has it yet so we wont know for a while. Is there a chance this software might work? Looks like they either support Android or Ubuntu OS.
https://shadow.tech/usen/applications
(07-26-2019, 10:30 PM)BeauS Wrote: Obviously no one has it yet so we wont know for a while. Is there a chance this software might work? Looks like they either support Android or Ubuntu OS.
With Android, probably will just work.
For Linux, it will be much trickier and less likely. That program only seems to be compiled for x86 PCs, which the PBP is not. QEMU user mode emulation might work.
There are other ways to stream PC games to the Pinebook Pro. Its possible to use Limewire (or whatever the software is called - works with Nvidia cards) and that will works perfectly fine *
* granted you'r AC network is stable, good etc., etc.,
(07-28-2019, 04:34 PM)Luke Wrote: There are other ways to stream PC games to the Pinebook Pro. Its possible to use Limewire (or whatever the software is called - works with Nvidia cards) and that will works perfectly fine *
Moonlight is the software. I remember trying to get it to run on MrFixIt's desktop image on the rockpro64, but it not working. It had something to do with it not finding a good X11 configuration for Moonlight to display. That was a while ago, so it may not still be valid. I'm really hoping I can get Moonlight to work with the PBP.
Limewire is an entirely different software, also used for streaming, but of an entirely different kind Smile
Look here - Recalbox in Docker on PBP.  Recalbox has moonlight installed. https://www.youtube.com/watch?v=wHAeEj05JqI&t=1s
Granted
There will surely be dedicated RetroArena builds too - which include moonlight iirc - and RA has a desktop, so its well suited for a laptop.
Granted
Thanks Luke, I'll definitely be doing this!
  Testing Some More Games on the Pinebook Pro! ImmyChan 5 3,531 09-24-2024, 01:43 AM
Last Post: pigkang
  Converting the Pinebook Pro into a CrowView Note like device 8jef 0 201 08-18-2024, 05:42 PM
Last Post: 8jef
  Pinebook Pro Initial Impressions kunger 443 653,362 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,971 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 883 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 629 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 621 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 537 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 1,240 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 1,391 02-01-2024, 11:35 AM
Last Post: tomekdev
