Pinebook Pro?
(05-10-2019, 01:38 AM)soupbowl Wrote:
(05-09-2019, 05:18 PM)Luke Wrote: the chosen keyboard is much better quality than the ANSI keyboard we currently have access to.
Will it suffer from the original Pinebooks problem of needing to mash the keys hard to register a keypress?
My only complaints with the original was the keyboard and trackpad. with both being replaced, this should be awesome.
Listen to the practical reason for going with ISO
I wonder if I would be able to use the Pinebook pro usb-c with my imac 2018 usb-c as an external display?
(05-10-2019, 04:37 AM)cocozozo Wrote: I wonder if I would be able to use the Pinebook pro usb-c with my imac 2018 usb-c as an external display?
I know nothing about the imac - does it do video in ?
Not sure to be honest... it might be video in with the display port only
If I recall correctly, for all new iMacs (after 2017?) to be used as monitors, the USB C had to be Thunderbolt 3 (or at best you could use Thunderbolt 3 to Thunderbolt 2 dongle).
I wouldn't bother with any dongles or trying to chain them, @cocozozo . Getting your iMac to be used as a monitor with non-Thunderbolt devices, will be an expensive and fruitless effort, unfortunately.
A decent secondary monitor would be a much better solution and will work (regardless if you will use for the iMac and/or the Pinebook Pro).
(05-10-2019, 06:27 AM)PakoSt Wrote: If I recall correctly, for all new iMacs (after 2017?) to be used as monitors, the USB C had to be Thunderbolt 3 (or at best you could use Thunderbolt 3 to Thunderbolt 2 dongle).
Damn..... seemed too good to be true. Thanks mate.
Deepin Linux support would be nice as well for this laptop
(05-10-2019, 02:55 PM)brent.thierens Wrote: Deepin Linux support would be nice as well for this laptop
I recommend you go to the Deepin forums and IRC channels to drum up support. Otherwise there are other partners that provide support. You can find them on the pine64 website.
Do you have an estimate when it will be on sale?
Last time and last place where I am answering this; we estimate that the Pinebook Pro will be available for purchase from the website late Summer 2019.
  Pinebook Pro Initial Impressions kunger 443 594,230 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,343 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 427 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 324 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 310 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 245 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 702 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 785 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,717 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,310 12-15-2023, 02:11 PM
