RockPro64 and 802.1q support [Solved]
Hi everyone,
In last week rockpro has been landed on my desk. I installed ubuntu minimal using the `pine64 Installer` which was describe in the official Resource tab.
I've tried to setup network, but it's immpossible for my home, as I don't see 8021q module for the kernel. It can not be loaded, as it's not compiled.
Could you tell me, if there is any other unofficial image, where the 8021q.ko is already buildin in the image? Specially with the userspace delivered with ubuntu?
If not, what is the problem of the rockpro64 kernel, that 802.1q is not supported?
Thanks for any tip
Cheers,
Hello
I receive also my RockPro last week and start to configure it.
I need also VLAN's for my settings.
I have installed the "Ubuntu 18.04 Minimal aarch64" from ayufan's with Etcher (which is new to me as I work usualy with Centos).
I am abble to setup VLAN by editing /etc/netplan/eth0.yaml (and use netplan)
It works for me as expected (no IP on the main eth0 but only on the eth0.xx interface).
Hope this can help you.
Pierre
Hi Ross,
thank you a lot for tip. Yes, you are right, that if I try to use netplan for the configuration of vlans then everything is working as you wrote.
Thanks, problem is solved now
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,858 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 182,666 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,374 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,213 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,314 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,713 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 131,506 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,852 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,313 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,897 01-13-2023, 06:21 PM
Last Post: misterc
