[Issue] Can't install the LibreElec Port from Raybuntu
Oke so i have a problem installing LibreElec onto the latest version of the Rock64.
Main problem: On first boot / auto-install of the O/S it keeps getting stuck. Everytime at a different spot; e.g. 3.xxxx / 26.xxxx.
The max i've seen is 66.xxxx.
I'm using the following setup:
PSU: 3A adapter from Pine64 webshop.
Board: ROCK64 4K60P HDR Media Board Computer - 4GB
Storage: Sandisk Ultra 32GB SDHC class 10. 2 cards.
I've tried the following firmware:
- LibreELEC-rock64.arm-rb-leia24.img.gz, on both cards.
- LibreELEC-rock64.arm-rb-leia23.img.gz, on both cards.
And i'm using the following software (within Win10X64) with both firmware for each :
- Win32DiskImager.
- Etcher.
In between i've repartitioned it to a 1 partition, did a format with all default, and after flashing ofc i've used the release before removal feature.
[media]https://pastebin.com/Ep6RrdEG[/media] <- thats an error log with 66% decompressed build 24 and being able to boot, If it's usefull.
Then tried to manually flashed the SPI to version 0.6.25, worked perfectly.
Next decompressing attempt: Stuck at 9.3 for about 15 minutes (jKy2y79Z.jpg), gave up.
It has been mentioned that version 21 should work best, as 24 should to, and 22/23 hmm well, less. But version 21 has been taken offline.
When trying Linux (stretch-mate-rock64-0.5.15-136-20171222-arm64.img) on the same SD card's, it works perfectly.
LibreELEC-ROCK64.aarch64-8.2-devel-20171004193222-r26173-gd404dbb.img -> The installation part works great, it autoreboots and everything (instead of the other versions) then it crashes after using it for a couple of minutes ([media]https://pastebin.com/1vwA8Yw2[/media]).
More information: Just received a 21th version on mIRC.
The USB is also really slow to show up, the same for the aarch64-8.2 version.
This one keeps rebooting =P
https://pastebin.com/HEjRJvc8
  OMV - Updates and Plug-in install broken MotoTom 0 5,837 06-26-2022, 01:21 PM
Last Post: MotoTom
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 4,536 10-30-2021, 06:10 AM
Last Post: Rocklobster
  Testing USB port(s) clach04 2 6,004 09-29-2021, 07:18 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 8,128 11-02-2020, 12:36 AM
Last Post: wilsonYan
Photo Has anyone been able to get a signal from the av/composite/cvbs port? bestpc 2 6,468 09-17-2019, 12:51 PM
Last Post: bestpc
  HDMI 2.0a CEC compliancy issue? Willem53 1 4,523 04-13-2019, 08:02 AM
Last Post: Willem53
  self-reboot issue pas059 6 12,413 02-11-2019, 05:02 AM
Last Post: pas059
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,622 02-05-2019, 05:41 PM
Last Post: ictele
  How can I install tvheadend server un rock64? gedas07 12 22,181 08-25-2018, 01:06 PM
Last Post: gedas07
  My Rock64 no power or light issue Nolaboy406 3 7,433 07-24-2018, 12:52 AM
Last Post: Luke
