Testing USB port(s)
I've been running and old ayufan rock64 build of OMV (v4) - I set it up 2020-01
I had been getting the occasional issue with the un-powered USB3 HD (only USB device plugged in) where it needed to be remounted.
About a two weeks or so ago, ssh sessions would consistently freeze when I tried to "ls" a specific directory and/or issue "df". SD access seemed.
I tried with a powered USB hub, with no change.
I had a small collection of rock64's that I picked up cheap and swapped out the board from the case (with fan) and the same SD card/OS, case, PSU, USB HD and it immediately worked fined. Its been running fine for 11 days now - with no incidents.
I suspect there is something going on with the USB ports (I'm guessing damaged).
Any suggestions on how to test the ports? Other than "df" and try accessing random directories?
I have another rock64 that I deployed with Armbian and Docker (with Pi Hole in a container) its been running solid for 4 months (NOTE this only has a USB2serial device on it) so I suspect I either got a flakey board originally or something in my environment has damaged the USB ports.
NOTE I'm planning on using Armbian for all my boards, I just haven't made the time to move OMV to Armbian+OMV5 yet.
So turns out my problems were actually the hard drive, the drive finally failed catastrophically
(09-27-2021, 09:07 PM)clach04 Wrote: So turns out my problems were actually the hard drive, the drive finally failed catastrophically
Same story as yourself. I've 5 Rock64s. Bad solders at the Ethernet and USB headers renders two of them inoperable. You can actually see a bit of movement when your pushing/pulling cables. They were definitely a bad batch.
Photo Has anyone been able to get a signal from the av/composite/cvbs port? bestpc 2 6,620 09-17-2019, 12:51 PM
Last Post: bestpc
  [Issue] Can't install the LibreElec Port from Raybuntu k0Lm_ 1 4,963 03-23-2018, 04:31 PM
Last Post: k0Lm_
  rock64 ethernet port sticker dkryder 1 5,342 11-14-2017, 10:18 PM
  USB-port powering & CEC support gonzo 7 16,885 08-07-2017, 10:36 AM
Last Post: gonzo
