Screen backlight accidentally zero %
Hi from Czech Republic, i am satisfied with my Pinebook 14", running original Linux MATE, however as I was changing slide bar of the screen brightness via touchpad, as i think there is no hardware shortcut like "Fn+something", i accidentally moved it to zero % and then manually switched off the Pinebook via long hold of the power button, so the screen is now after every log-in totally dark. I can run up Guest session, but once I log into my account, it becomes dark. External HDMI does not run (i never tested before, just tried now and TV says no signal). I know i can run up Terminal via shortcut CTRL+ALT+T, however what next then, step by step pls.? I tried to play with "xbacklight" advise in Guest session and also my account, but i am not sure i am doing the steps in correct synchronizations (blind typing, lack of Guest password knowledge, lack of knowledge if xbacklight is installed or not, etc.). Thx to experts to let me know fast!
Try "sudo su" and then:
root@pinebook:/home/pine64# echo 255 > /sys/class/backlight/lcd0/brightness
(08-31-2017, 12:30 PM)shirman Wrote: Try "sudo su" and then:
try:   sudo  -i
Wink
Just go into a dark room with a flashlight, and if you use the flashlight on the pinebooks screen, you can see what is going on it, with a little bit of patience you can get yourself into settings and move the brightness slider back up Wink
(09-04-2017, 01:10 PM)TomC601 Wrote: Just go into a dark room with a flashlight, and if you use the flashlight on the pinebooks screen, you can see what is going on it, with a little bit of patience you can get yourself into settings and move the brightness slider back up Wink
Yes,  I would recommend an LED flashlight;  one of the high intensity ones with like 14+ LEDs.
Thanks to all, solution was really just in getting in dark room and using flashlight very close to the screen, just right above it. I thought the screen is completely off, but its not. I have manually moved slide to higher brightness % level back again. Things are sometimes simplier then they seems... I am SURE somebody will use this after me as well, this thing will repeat :-) PS: no other issues so far while running Pinebook as occassional home NTB...
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 32,514 04-27-2020, 06:27 AM
  Failure in setting the display backlight with Armbian 5.86 [SOLVED] wlad 0 3,910 06-11-2019, 03:36 AM
Last Post: wlad
  Blank Screen on Boot MECZero 4 12,197 05-12-2019, 11:54 AM
Exclamation Armbian - need help, locked out myself by setting backlight to zero UltraBloxX 6 13,230 03-31-2019, 12:36 PM
Last Post: guidol
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 16,432 12-02-2018, 05:37 AM
Last Post: mikee3000
  Pinebook Ubuntu XFCE screen resolution options Fox7799 2 7,468 12-01-2018, 06:05 PM
Last Post: Fox7799
  Dimmed screen too much in plasma boballen55 1 5,652 11-09-2018, 03:42 PM
Last Post: boballen55
  How to test the emmc(usdhc2) diver and pwm backlight driver? vinothkumar 0 3,511 12-29-2017, 11:40 PM
Last Post: vinothkumar
