Pinebook Linux Power-Down Procedure
Information
Greetings,
The Pinebook Linux Power-Down Procedure that has been found to be most effective (although not 100% reliable) is to use the "power button" to pull up the shutdown dialogue !
Testing has shown that if the shutdown command happens in a terminal (or serial console), or if it is selected with the mouse from the System menu or the tool-bar the system  correctly hits the systemd target shutdown;  however, the hardware ARISC PMIC does not power off the system.
On the other hand,  if the user will press the actual "power button"  (upper right hand key on the keyboard)  then after the systemd  target shutdown the hardware will correctly (most of the time) power off the hardware.
... but don't trust it,  check it !!
Shy
Good to know! Indeed I've experienced that sometimes a reboot or shutdown doesn't seem to complete properly, will hit the power button only for now to see if indeed proper shutdown is done! Smile
Greetings,
In this segment I have captured the OS shutdown to :  target shutdown ( look for it in the log below );  beginning with the OS unmounting of the Local File Systems (the critical piece of shutdown )!
After this line:
                [  OK  ] Reached target Shutdown.
...  we see the power down console messages ( usually never seen by human eyes ) and a long string of messages beginning with this line:
                 [48025.784817] Power down.   ( look for "hello boot0 starting" )
... and culminating in this line ultimately if the hardware actually powers OFF :
                 [      8.036]power off set power off vol to default
Lowly humans get to see a brief  battery charging icon on the screen at this point ( boot0 arisc uboot ).
Its amazing what we can learn about the system ( hardware and software ) by studying the serial console logs !
[  OK  ] Stopped target Local File Systems.                                             Unmounting /run/user/1000...                                                   Unmounting /boot...                                                     [  OK  ] Removed slice system-systemd\x2dbacklight.slice.                       [  OK  ] Unmounted /run/user/1000.                                               [  OK  ] Unmounted /boot.                                                       [  OK  ] Stopped File System Check on /dev/mmcblk0p1.                           [  OK  ] Removed slice system-systemd\x2dfsck.slice.                             [  OK  ] Reached target Unmount All Filesystems.                                 [  OK  ] Stopped target Local File Systems (Pre).                               [  OK  ] Stopped Create Static Device Nodes in /dev.                             [  OK  ] Stopped Remount Root and Kernel File Systems.                           [  OK  ] Reached target Shutdown.                                               [48025.784817] Power down.                                                       INFO:    PSCI Affinity Map:                                                     INFO:      AffInst: Level 2, MPID 0x0, State ON                                 INFO:      AffInst: Level 1, MPID 0x0, State ON                                 INFO:      AffInst: Level 0, MPID 0x0, State ON                                 INFO:      AffInst: Level 0, MPID 0x1, State OFF                                 INFO:      AffInst: Level 0, MPID 0x2, State OFF                       ( console messages stop here if the pinebook is unplugged )                       HELLO! BOOT0 is starting!                                                       boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f        boot0 version : 4.0.0                                                           set pll start        set pll end        rtc[0] value = 0x00000000                                                       rtc[1] value = 0x00000000                                                       rtc[2] value = 0x00000000                                                       rtc[3] value = 0x0000a101                                                       rtc[4] value = 0x00000000                                                       rtc[5] value = 0x00000000                                                       DRAM driver version: V1.1                                                       start ddr type auto scan mode                                                   rsb_send_initseq: rsb clk 400Khz -> 3Mhz                                         PMU: AXP81X        ddr voltage = 1280 mv                                                           DRAM init OK        lpddr3 try success                                                               DRAM Type = 7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)                                 DRAM clk = 408 MHz                                                               DRAM zq value: 003939b9                                                         DRAM dual rank full DQ gate training OK                                         DRAM size = 2048 MB                                                             DRAM init ok        dram size =2048        card boot number = 2, boot0 copy = 0                                             card no is 2        sdcard 2 line count 8                                                           [mmc]: mmc driver ver 2015-05-08 20:06                                           [mmc]: Wrong media type 0x00000000                                               [mmc]: ***Try SD card 2***                                                       [mmc]: mmc 2 cmd 8 timeout, err 00000100                                         [mmc]: mmc 2 cmd 8 err 00000100                                                 [mmc]: mmc 2 send if cond failed                                                 [mmc]: mmc 2 cmd 55 timeout, err 00000100                                       [mmc]: mmc 2 cmd 55 err 00000100                                                 [mmc]: mmc 2 send app cmd failed                                                 [mmc]: ***Try MMC card 2***                                                     [mmc]: MMC 5.0        [mmc]: HSDDR52/DDR50 8 bit                                                       [mmc]: 50000000 Hz                                                               [mmc]: 14800 MB        [mmc]: ***SD/MMC 2 init OK!!!***                                                 sdcard 2 init ok        The size of uboot is 000f8000.                                                   sum=dda0f53d        src_sum=dda0f53d        0x00000002 0x00000000                                                           0x00000000 0x00000000                                                           0x00000000 0x00000000                                                           0x00000000 0x00000000                                                           0x00000000 0x00000000                                                           Succeed in loading uboot from sdmmc flash.                                       boot0: start load other image                                                   boot0: Loading BL3-1                                                             Loading file 0 at address 0x40000000,size 0x0000a400 success                     boot0: Loading scp                                                               Loading file 2 at address 0x00040000,size 0x00019c00 success                     set arisc reset to de-assert state                                               Ready to disable icache.                                                         é  Configuring SPC Controller                                                   NOTICE:  BL3-1: v1.0(debug):864ef11                                             NOTICE:  BL3-1: Built : 21:59:22, May  8 2017                                   INFO:    BL3-1: Initializing runtime services                                   INFO:    BL3-1: Preparing for EL3 exit to normal world                           INFO:    BL3-1: Next image address = 0x4a000000                                 INFO:    BL3-1: Next image spsr = 0x1d3        U-Boot 2014.07-00014-gc616876 (May 30 2017 - 18:44:41) Allwinner Technology        uboot commit : c616876a3e07117d9bf1a5fdadbc7e7c233c4f34        rsb: secure monitor exist                                                       [      0.433]pmbus:   ready                                                     [      0.436][ARISC] :arisc initialize                                           [      0.969][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table         [SCP] :sunxi-arisc driver begin startup 2                                       [SCP] :arisc_para size:1a8                                                       [SCP] :arisc version: [v0.1.76]                                                 [SCP] :sunxi-arisc driver v1.10 is starting                                     [      1.162][ARISC] :sunxi-arisc driver startup succeeded                       [      1.214]PMU: AXP81X                                                         [      1.216]PMU: AXP81X found                                                   bat_vol=4180, ratio=100                                                         [      1.224]PMU: dcdc2 1100                                                     [      1.227]PMU: cpux 1008 Mhz,AXI=336 Mhz                                     PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz                   device_type = 3253, onoff=1                                                     dcdc1_vol = 3300, onoff=1                                                       dcdc2_vol = 1100, onoff=1                                                       dcdc6_vol = 1100, onoff=1                                                       aldo1_vol = 2800, onoff=0                                                       aldo2_vol = 1800, onoff=1                                                       aldo3_vol = 3000, onoff=1                                                       dldo1_vol = 3300, onoff=0                                                       dldo2_vol = 2500, onoff=0                                                       dldo3_vol = 2800, onoff=0                                                       dldo4_vol = 3300, onoff=1                                                       eldo1_vol = 1800, onoff=1                                                       eldo2_vol = 1800, onoff=0                                                       eldo3_vol = 1800, onoff=0                                                       fldo1_vol = 1200, onoff=0                                                       fldo2_vol = 1100, onoff=1                                                       gpio0_vol = 3100, onoff=1                                                       vbus not exist        normal dc exist, limit to dc                                                     run key detect        no key found        no uart input        DRAM:  2 GiB        fdt addr: 0xb6eb99c0                                                             Relocation Offset is: 75f0c000                                                   In:    serial        Out:   serial        Err:   serial        gic: sec monitor mode                                                           [      1.588]start                                                               drv_disp_init        init_clocks: finish init_clocks.                                                 fdt_get_one_gpio lcd0.lcd_gpio_2 fail                                           fdt_get_one_gpio lcd0.lcd_gpio_3 fail                                           fdt_get_one_gpio lcd0.lcd_gpio_scl fail                                         fdt_get_one_gpio lcd0.lcd_gpio_sda fail                                         pwm_request: reg = 0x1c21400.pchip->pwm = 0                                     reg_busy_offset=0, reg_busy_shift = 0, reg_enable_offset = 0                     request pwm success, pwm = 0!                                                   sunxi_pwm_config: reg_shift = 0, reg_width = 4, prescale temp = 20, pres=0       PWM _TEST: duty_ns=976562, period_ns=5000000, freq=200, per_scal=1, period_reg=3 enable power vcc-hdmi-33, ret=0                                                 drv_disp_init finish                                                             boot_disp.output_disp=0                                                         boot_disp.output_type=1                                                         boot_disp.output_mode=4                                                         fetch script data boot_disp.auto_hpd fail                                       disp0 device type(1) enable                                                     disp 0, clk: pll(560000000),clk(560000000),dclk(80000000) dsi_rate(560000000)       clk real:pll(556875000),clk(556875000),dclk(79553571) dsi_rate(0)           enable power vcc-mipi, ret=0                                                     enable power vcc-hsic-12, ret=0                                                 enable power vcc-lvds, ret=0                                                     enable power vcc-pd, ret=0                                                       [      3.178]end        workmode = 0,storage type = 2                                                   [      3.183]MMC:        2                                                       [mmc]: mmc driver ver 2015-06-03 13:50:00                                       [      3.194]        lcd_edp_tx_rate=2,                                                               lcd_edp_tx_lane=1,                                                               lcd_edp_colordepth=1,                                                           lcd_model_name=2        [      3.204]ANX9807 Chip found                                                 [      3.310]..................................clock is detected.               [      3.339]..................................clock is stable.                 sunxi_pwm_config: reg_shift = 0, reg_width = 4, prescale temp = 70, pres=0       PWM _TEST: duty_ns=996094, period_ns=5000000, freq=200, per_scal=1, period_reg=7 sunxi_pwm_config: reg_shift = 0, reg_width = 4, prescale temp = 70, pres=0       PWM _TEST: duty_ns=996094, period_ns=5000000, freq=200, per_scal=1, period_reg=7 [mmc]: get sdc_ex_dly_used 2, use auto tuning sdly                               [mmc]: card2 io is 1.8V.                                                         SUNXI SD/MMC: 2        [mmc]: start mmc_calibrate_delay_unit, don't access device...                   [mmc]: delay chain cal done, sample: 200(ps)                                     [mmc]: delay chain cal done, ds: 200(ps)                                         [mmc]: media type 0x0                                                           [mmc]: Wrong media type 0x0                                                     [mmc]: ************Try SD card 2************                                     [mmc]: mmc 2 cmd 8 timeout, err 100                                             [mmc]: smc 2 err, cmd 8,  RTO                                                   [mmc]: mmc 2 close bus gating and reset                                         [mmc]: mmc 2 mmc cmd 8 err 0x00000100                                           [mmc]: mmc send if cond failed                                                   [mmc]: mmc 2 cmd 55 timeout, err 100                                             [mmc]: smc 2 err, cmd 55,  RTO                                                   [mmc]: mmc 2 close bus gating and reset                                         [mmc]: mmc 2 mmc cmd 55 err 0x00000100                                           [mmc]: send app cmd failed                                                       [mmc]: ************Try MMC card 2************                                   [mmc]: mmc don't support HS400                                                   [mmc]: host caps: 0xef                                                           [mmc]: MID 000088 PSN 0feb0460                                                   [mmc]: PNM NCard  -- 0x4e-43-61-72-64                                           [mmc]: PRV 4.3        [mmc]: MDT m-8 y-2016                                                           [mmc]: MMC v5.0        [mmc]: speed mode     : HSSDR52/SDR25                                           [mmc]: clock          : 50000000 Hz                                             [mmc]: bus_width      : 8 bit                                                   [mmc]: user capacity  : 14800 MB                                                 [mmc]: boot capacity  : 4096 KB                                                 [mmc]: rpmb capacity  : 4096 KB                                                 [mmc]: ************SD/MMC 2 init OK!!!************                               [mmc]: ========best spd md: 3-HS200/SDR104, freq: 5-200000000                   [mmc]: erase_grp_size      : 0x400WrBlk*0x200=0x80000 Byte                       [mmc]: secure_feature      : 0x55                                               [mmc]: secure_removal_type : 0x9                                                 [mmc]: EOL Info(Rev blks): Normal                                               [mmc]: Wear out(type A): 0%-10% life time used                                   [mmc]: Wear out(type B): 0%-10% life time used                                   [      4.128]sunxi flash init ok                                                 [mmc]: MMC Device 0 not found                                                   ** Bad device mmc 0 **                                                           Using default environment        --------fastboot partitions--------                                             mbr not exist        base bootcmd=run mmcbootcmd                                                     bootcmd set setargs_mmc                                                         key 0        recovery key high 12, low 10                                                     fastboot key high 6, low 4                                                       no misc partition is found                                                       to be run cmd=run mmcbootcmd                                                     update dtb dram start                                                           update dtb dram  end                                                             serial is: 8400503443181809058e                                                 check for ANX9807                                                               found ANX9807 chip                                                               Pine64 model: pine64-pinebook                                                   PowerBus = 2(0: not exist 1:vBus 2:acBus 3:vBus&acBus)                           pre charge mode        sunxi_bmp_charger_display                                                       [mmc]: Has init        [      4.754]---drivers/mmc/mmc.c 2733 mmc_init                                 reading bat\battery_charge.bmp                                                   89334 bytes read in 7 ms (12.2 MiB/s)                                           bmp file buffer: 0x41000000, bmp_info.buffer: 47400000                           fetch script data boot_disp.output_full fail                                     screen_id =0, screen_width =1366, screen_height =768                             frame buffer address 47400036                                                   set next system normal                                                           drv_disp_exit        [mmc]: mmc exit start                                                           [mmc]: start mmc_calibrate_delay_unit, don't access device...                   [mmc]: delay chain cal done, sample: 185(ps)                                     [mmc]: delay chain cal done, ds: 192(ps)                                         [mmc]: mmc 2 exit ok                                                             [      8.036]power off                                                           set power off vol to default
At this point the hardware has successfully powered down , and if the Pinebook is plugged in charging begins !
Shy
Greetings Pinebook fans !
... the plot thickens.  Powering down with the "power-button"  and then clicking the "shutdown" button is the best;  but the Pinebook can be successfully powered off from the terminal too !
       sudo poweroff      <==== use this one
  vs
       sudo halt
More likely than not  sudo halt  will leave the Pinebook in a powered up state;  from a hardware perspective.  On the other hand,  sudo poweroff  will more likely than not result in the hardware actually powering off the system.
Shy
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,162 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,030 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,546 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 6,236 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,727 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,503 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,733 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,092 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,839 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,768 01-20-2021, 11:18 AM
