After update - won't power up with HDMI connected
OK - now my Pine64+ (2 GB) won't stay "on" when I've got it connected to my lapdock.  Longsleep latest Debian XFCE build...
It was working before I did :
https://www.pine64.pro/getting-started-linux/  :
sudo -i
/usr/local/sbin/pine64_update_uboot.sh
/usr/local/sbin/pine64_update_kernel.sh
resize_rootfs.sh
reboot
(didn't need to resize - I already did that from GParted on my Linux workstation)
When I power it up, either from the power button, or plugging into mains (i.e. USB otg) - it stays up...
Once it's up - and - staying up - if I plug it into my Lapdock - I get nothing output...
If I try to power it up connected to the Lapdock - either drawing power from the Lapdock or direct from mains (i.e. USB otg) the PWR LED will come on for about 5-10 seconds then it shuts off again.
If I can get it "rescued" from this state (e.g. SSH over ethernet [I don't know what IP address it's getting over work's WiFi]) I'm going to rename the host to pezzo-di-merda...
it's obvious there is some kind of conflict between the lapdock and pine64 but imo it is jumping to conclusions to say that the conflict is due to some fault of the pine64. most lapdocks are proprietary in nature in that they are designed for specific phones or series of phones. to offer any suggestions i would have to know more about the lapdock, how it is connected and info on what it was built to do with as many details/specifics as possible since the term lapdock can reference so many things. even if you are just plugging into an hdmi port, some ports are designed to offer services beyond just a standard hdmi signal or designed to be expecting signals the pine64 is not offering.
(09-09-2016, 01:14 AM)dkryder Wrote: it's obvious there is some kind of conflict between the lapdock and pine64 but imo it is jumping to conclusions to say that the conflict is due to some fault of the pine64. most lapdocks are proprietary in nature in that they are designed for specific phones or series of phones. to offer any suggestions i would have to know more about the lapdock, how it is connected and info on what it was built to do with as many details/specifics as possible since the term lapdock can reference so many things. even if you are just plugging into an hdmi port, some ports are designed to offer services beyond just a standard hdmi signal or designed to be expecting signals the pine64 is not offering.
It worked almost perfectly (wrong resolution, 1280x720 - but it was usable) before the update - and it still works perfectly with my Banana PI and my NTC CHIP SBCs (both of which sync to the correct resolution of 1366x768).  Also - the power shutoff when I try to power it up connected to the lapdock is worrying.
Basically - it's a Motorola Atrix Lapdock (the "most" compatible model) - connected via HDMI and USB....  USB for the keyboard, HDMI for the display...
Anyway - I don't have my serial/UART dongle with me here at work - and I don't know if it's getting as far as WiFi - so I cannot connect to it to see what's going on - will have a look when I get home from work tonight - both UART and ethernet (I know what IP address it gets on my home LAN).
have you tried using the boot configuration file to set a specific resolution, perhaps the lowest standard which is known to be fairly problem free , either 720p, 720p60 or whatever a known resolution to work well?
(09-09-2016, 02:41 AM)dkryder Wrote: have you tried using the boot configuration file to set a specific resolution, perhaps the lowest standard which is known to be fairly problem free , either 720p, 720p60 or whatever a known resolution to work well?
I've tried every combo known to mankind!
Only two ever display 720p, if I tried to set it to "768p " or "768p60" the "paskaläjä" goes to 1080p...  that is when it boots - which is like about 25% of the time (and was 0% of the time earlier today!)
I'm happy with 720p - it's not just a matter of it not displaying - it just doesn't boot - never appears on the network...
I hooked up a UART and I get a whole heap of errors about uboot...
I cracked open the C4 case, disconnected the battery (and move the BAT jumper) - and now it boots "some of the time"...
I've got two of them (Pine 64+ 2 GB) - the other one which was running Armbian boots fine...  which would kinda suggest the hardware on this board is a bit dodgy - and I'm not surpised at all - given that BOTH boards arrived with an ugly bow or bend in the middle (this has been reported by many recipients of Pine64).
Anyway - I have renamed it to "pezzo-di-merda" - because that is what it is...   I'd really like my money back - I'd pay another $50 for just ONE 2G multi-core ARM board (but most definitely NOT from the people who brought us Pine!) - and I don't really give a rat's about 32 bit or 64 bit...
Here's some of the stuff that gets echoed through the UART :
root@tengri:/dev# cu -l /dev/ttyUSB0 -s 115200
Connected.
[  766.316056] BUG: soft lockup - CPU#0 stuck for 23s! [kworker/0:1:30]
[  766.326310] Modules linked in: cfg80211(+)
[  766.334109]
[  766.339013] CPU: 0 PID: 30 Comm: kworker/0:1 Not tainted 3.10.102-3-pine64-longsleep #98
[  766.351354] Workqueue: events start_work
[  766.359073] task: ffffffc078b52f80 ti: ffffffc078b54000 task.ti: ffffffc078b54000
[  766.370698] PC is at __do_softirq+0xb4/0x2d8
[  766.378690] LR is at __do_softirq+0x30/0x2d8
[  766.386677] pc : [<ffffffc0000b5f78>] lr : [<ffffffc0000b5ef4>] pstate: 40000145
[  766.398216] sp : ffffffc078b57910
[  766.405295] x29: ffffffc078b57910 x28: ffffffc000a6a0c0
[  766.414617] x27: ffffffc000a6a000 x26: ffffffc078b57910
[  766.423938] x25: 0000000000000000 x24: 000000000000000a
[  766.433272] x23: 0000000080000145 x22: ffffffc078b57a40
[  766.442598] x21: ffffffc078b54000 x20: 000000000000001e
[  766.451942] x19: 0000000000000202 x18: 0000000000000019
[  766.461284] x17: 000000000000000e x16: 0000000000000007
[  766.470605] x15: 0000000000000001 x14: 0000000000000007
[  766.479930] x13: 000000000000000e x12: ffffffc078b57900
[  766.489283] x11: 0000000000000007 x10: 000000000000000e
[  766.498664] x9 : 0000000225c17d03 x8 : 000000000fe0062f
[  766.508074] x7 : 0014dc938067c280 x6 : ffffffc078b54000
[  766.517521] x5 : 0000000029aaaaab x4 : 0000000000a83822
[  766.526993] x3 : 0000000000000020 x2 : ffffffc000be0900
[  766.536488] x1 : ffffffc000be0900 x0 : 0000000000000000
[  766.545994]
[  766.545994] PC: 0xffffffc0000b5ef8:
[  766.558793] 5ef8  b0004da1 9272c746 f940a022 8b020000 f9003fa0 f94008c0 b9401402 b9008fa2
[  766.571660] 5f18  2a0203e2 12147842 b9001402 912402a2 b98054c0 d37ae400 b8606853 b94050c0
[  766.584610] 5f38  11040000 b90050c0 b0004dbb b94054c0 f90043b5 9103037c aa0603f5 52800158
[  766.597620] 5f58  f90037a1 b9008ba0 f94043a0 91240001 b98056a0 d37ae400 b820683f d50342ff
[  766.610687] 5f78  d2800014 91030360 8b140000 f9003ba0 360009f3 f0004d20 9343fe96 91356000
[  766.623835] 5f98  b94052b7 d538d082 8b364800 2a1603f9 91002000 b8626801 11000421 b8226801
[  766.637060] 5fb8  d503201f 14000017 b94056a1 52800800 90003382 1ac00c20 f9472c42 937d7c00
[  766.650365] 5fd8  f8606840 9ac12400 360001c0 b94052a0 11000400 b90052a0 f00057e0 91002000
[  766.663746]
[  766.663746] LR: 0xffffffc0000b5e74:
[  766.677915] 5e74  a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d503201f
[  766.691477] 5e94  f9404661 aa1303e0 d63f0020 340000c0 a9418662 aa1303e0 52800003 cb010042
[  766.705105] 5eb4  94008230 f9400bf3 a8c27bfd d65f03c0 a9b77bfd 910003fd a90153f3 a9025bf5
[  766.718803] 5ed4  a90363f7 a9046bf9 a90573fb aa1e03e0 f0005955 d503201f 52800040 97fffc02
[  766.732567] 5ef4  910003fa b0004da1 9272c746 f940a022 8b020000 f9003fa0 f94008c0 b9401402
[  766.746409] 5f14  b9008fa2 2a0203e2 12147842 b9001402 912402a2 b98054c0 d37ae400 b8606853
[  766.760320] 5f34  b94050c0 11040000 b90050c0 b0004dbb b94054c0 f90043b5 9103037c aa0603f5
[  766.774294] 5f54  52800158 f90037a1 b9008ba0 f94043a0 91240001 b98056a0 d37ae400 b820683f
[  766.788344]
[  766.788344] SP: 0xffffffc078b57890:
[  766.803807] 7890  0000001e 00000000 78b54000 ffffffc0 78b57a40 ffffffc0 80000145 00000000
[  766.818010] 78b0  0000000a 00000000 00000000 00000000 78b57910 ffffffc0 00a6a000 ffffffc0
[  766.832229] 78d0  00a6a0c0 ffffffc0 78b57910 ffffffc0 000b5ef4 ffffffc0 78b57910 ffffffc0
[  766.846502] 78f0  000b5f78 ffffffc0 40000145 00000000 000001c0 00000000 0000001e 00000000
[  766.860806] 7910  78b579a0 ffffffc0 000b6288 ffffffc0 000001c0 00000000 0000001e 00000000
[  766.875142] 7930  00000000 00000000 78b57a40 ffffffc0 80000145 00000000 00000001 00000000
[  766.889499] 7950  00000000 00000000 00000140 00000000 00000001 00000000 78b54000 ffffffc0
[  766.903897] 7970  78805840 ffffffc0 00a6a000 ffffffc0 78b579c0 ffffffc0 ffff8c86 00000000
[  766.918366]
[  766.918366] X1: 0xffffffc000be0880:
[  766.934726] 0880  00000000 00000000 00000000 00000000 00bb3670 ffffffc0 00000000 00000000
[  766.949371] 08a0  00000000 00000000 0000000f 00000000 0000000f 00000000 00000000 00000000
[  766.963937] 08c0  0000000f 00000000 00000000 00000000 0000000f 00000000 00000000 00000000
[  766.978356] 08e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  766.992613] 0900  00000282 0000018b 0000004e 00000005 00000000 00000000 00000000 00000000
[  767.006806] 0920  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  767.020937] 0940  00000000 0000037c 0000003c 00000002 00000000 00000000 00000000 00000000
[  767.035037] 0960  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  767.049039]
[  767.049039] X2: 0xffffffc000be0880:
[  767.064208] 0880  00000000 00000000 00000000 00000000 00bb3670 ffffffc0 00000000 00000000
[  767.078132] 08a0  00000000 00000000 0000000f 00000000 0000000f 00000000 00000000 00000000
[  767.092079] 08c0  0000000f 00000000 00000000 00000000 0000000f 00000000 00000000 00000000
[  767.105928] 08e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  767.119692] 0900  00000282 0000018b 0000004e 00000005 00000000 00000000 00000000 00000000
[  767.133438] 0920  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  767.147175] 0940  00000000 0000037c 0000003c 00000002 00000000 00000000 00000000 00000000
[  767.160879] 0960  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  767.174562]
[  767.174562] X6: 0xffffffc078b53f80:
and it goes on and on and echoes such similar garbage ad nauseum infinitum...
This has really been quite a disheartening experience with these boards - especially after the rock solid support and stability of the Banana PI and the NTC CHIP...  FFS - I'd be happy with something like the BPi with another couple of cores and a further GB of RAM...
Oh well....  Kickstarter's always a risk - took a punt and lost on really REALLY shoddy hardware and support...
Sayonara!  I might head on over to Armbian... Catcha yas on the flipside!
aufweidersehen
Try another version of OS frm Longsleep or Lenny.
If it doesn't work, try to replace power supply,maybe it is out.
If this also fails or you do not want it any more, send it free to me Smile
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,986 07-28-2020, 01:49 PM
Last Post: kuleszdl
  root running from usb connected ssd locks up system marcelser 0 4,496 11-17-2017, 04:50 PM
Last Post: marcelser
  NIC not visible after kernel update xleon 1 5,271 11-15-2016, 05:23 PM
Last Post: xleon
  For those with HDMI issues, till we get a fix Xrdp works rahlquist 0 3,895 04-10-2016, 12:45 AM
Last Post: rahlquist
