Short Guide to Using OpenVPN client GUI and .ovpn config file on PP
A pretty simple guide, Mobian Trixie is setup to use wireguard for VPNs.
It is pretty easy to add openVPN client services though.
first install two packages
sudo apt install openvpn network-manager-openvpn-gnome
now the Gnome openVPN network GUI expects you to hand it all of your certificates separately but you can have the CLI add your .ovpn file which I had generated on my  openVPN server running on my Debian VPS.
The .ovpn file contains all of the settings and certificates you need to make the connection though for some services you also need to add your username and password.
sudo nmcli connection import type openvpn file /home/mobian/exampleVPN.ovpn
Easy as that for your own VPN server's  .ovpn file or one you get from ProtonVPN or other VPN service.
In trixie you even get a clicker button in the pulldown notification area along with bluetooth battery and wifi toggles once the VPN is setup.
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 7,891 09-05-2023, 11:16 AM
Last Post: nickolas
  Screen stay black unless power key pressed short freelectro 0 2,665 06-24-2023, 01:55 PM
Last Post: freelectro
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,584 01-07-2023, 09:36 AM
Last Post: dcarvil
  How to deal with overloaded config files? jsch 1 3,379 10-02-2022, 02:46 PM
Last Post: treebeard
  low disk space on file system root revisited benedikt55 2 4,559 09-24-2022, 10:16 AM
Last Post: benedikt55
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 14,752 09-05-2022, 12:10 AM
  I'd like to have a Discord client on Mobian lsitongia 3 7,149 04-30-2022, 07:32 PM
Last Post: TRS-80
  This Qutebrowser config file made browsing on the PinePhone great again ryo 0 3,580 01-05-2022, 05:49 PM
Last Post: ryo
  can't get file transfer working. Help, please! quixote 26 38,155 11-14-2021, 10:50 PM
Last Post: quixote
  File Transfer With Bluetooth food 0 2,643 10-29-2021, 11:00 AM
Last Post: food
