Mobian OS
Dear all,
I have installed Mobian on the pinetab 2 using an SD-card. The kernel is Linux 6.8.-rockchip. I can connect to Wifi via a USB-dongle. Is it possible to move to another kernel which includes the bes2600 driver?
Thanks an kind regards,
Stefan
Realistically since the kernel modules are not included for FOSS certification beyond-a-doubt reasons an installer script found here would be enough just a few wgets and echos to get the bin and point the OS at it.
If an installer script is put together and updated the Bluetooth and camera drivers and setup should be included too.  I would like to be able to use my USB mouse and scan QR codes on my phone, laptop and other.
How much work is involved and where is the guide
there is this
https://wiki.pine64.org/images/4/4d/Pine..._Guide.pdf which recommends USB adapters
https://forum.pine64.org/showthread.php?tid=18541  which shows a mobian non-free firmware repo to add for wifi(wifi only?)
"deb http://repo.mobian.org/ staging main non-free-firmware"
https://wiki.debian.org/InstallingDebian...4/PineTab2 un-updated says the wifi is not Mobians problem leave us alone
Cameras
https://forum.pine64.org/showthread.php?tid=19109
there was much work and maybe success a year ago we don't see this yet
Bluetooth
https://forum.pine64.org/showthread.php?tid=19260
an attempt at a fix for a supposedly working BT activation on arch
I am still using the arch install and have wifi but wanted BT too and this DID NOT work https://redlib.perennialte.ch/r/PINE64of...pinetab_2/
  Where to find older Mobian image? guenther 2 3,306 10-30-2024, 02:50 AM
Last Post: guenther
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 11,284 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 17,553 12-13-2023, 11:04 AM
Last Post: diederik
  Mobian won't boot after ton of updates bartgrefte 11 16,588 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Mobian - Phosh frtodd 1 3,394 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  New images with 6.1 kernel won't boot (mobian / postmarketos) gischpelino 0 2,566 01-17-2023, 11:36 AM
Last Post: gischpelino
  PineTab Mobian bcnaz 150 249,590 04-26-2022, 11:58 AM
Last Post: thomzane
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 7,640 04-30-2021, 06:52 AM
Last Post: thomzane
  PineTab Mobian LXDE desktop fjord 0 3,779 02-24-2021, 06:32 PM
Last Post: fjord
  Pinetab Mobian optimization tomoqv 13 23,078 02-06-2021, 04:36 AM
Last Post: barray
