Replacement battery for PineBook Pro
hi!
After 4 years of use, the battery of my PineBook Pro is really swollen, I should change it soon~ish.
Currently, it seems out of stock on the official store, and the European store doesn't even sell spare batteries.
So: has anyone had success procuring batteries elsewhere?
I haven't yet, but just a quick search turns up several that look like they would work, including this one
https://www.cdrtd.com/products/laptop-ba...-5pin.html
:wq
(09-25-2023, 07:12 AM)KC9UDX Wrote: I haven't yet, but just a quick search turns up several that look like they would work, including this one
That one specifically is not compatible, it's the 5pin variant, whereas the Pinebook Pro uses the 7pin avriant instead.
But cdrtd seem to have that one too.
But I don't know how much cdrtd is a reliable source for laptop parts. I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
(09-25-2023, 09:44 AM)DrYak Wrote: I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
Update regarding my battery problem:
  • still no answer from Pine64 themselves
  • but since then I bought one from Ali mentionned above, replaced it, charged it, seems to work.
I'll update in a few weeks whether this battery still holds charge or if it degraded too quick.
  pinebook pro dixplays vertical stripes WEF 2 2,954 03-23-2025, 03:31 PM
Last Post: WEF
  Replacement main board for Developers mozes 11 8,952 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 1,543 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 4,339 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 2,131 10-14-2024, 05:35 PM
  Yet another new Pinebook keyboard problem MikoBob 3 3,493 09-11-2024, 07:05 AM
Last Post: MikoBob
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 6,620 05-06-2024, 09:27 AM
  Lithium Battery Connector Franestra 0 2,023 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,189 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,117 02-17-2024, 07:06 PM
