Is it normal for the pinephone to "discharge" after fully charged on multiple OS?
I got a pinephone a few days ago and admittedly I haven't had many phones but this is something I've never encountered before. I've tried numerous OS and every single one has this problem. I've searched and couldn't find anything about how normal it is for a pinephone. If I unplug and plug the charger back in it will start charging again until it is full and the cycle repeats, I'm not sure how far until it starts charging again if it ever does but I've let it get as low as 70%. The fact that I have to unplug and plug the charger back in is also a bit concerning. On the OS it ships with (at least after I manually reinstalled it, I didn't check it as it came shipped), manjaro with plasma mobile it says health is 0% and the battery is unknown.
It can slightly discharge after reaching 100% so that the battery is not stressed by constant charging, but it should not go as low as 70% while plugged in, mine does not do that. At something like 90-95%, it should start charging again.
Edit: Just an update, I don't know why but it seems to be charging at some point on it's own after a while now. When and why it does seems a bit unknown to me but just thought I'd say that it's working good enough for me now.
(05-10-2023, 09:24 PM)Kevin Kofler Wrote: It can slightly discharge after reaching 100% so that the battery is not stressed by constant charging, but it should not go as low as 70% while plugged in, mine does not do that. At something like 90-95%, it should start charging again.
Thanks. Is there possibly something I can do if it is going lower than it's supposed to then?
  Pinephone software Csanderson0313 3 1,072 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 83,525 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,108 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,957 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,967 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,402 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,804 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,414 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,900 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,801 10-21-2025, 12:12 PM
Last Post: Richy_T
