Mobian has new separate packages to support the PinePhone Pro
#21
(03-15-2023, 10:08 AM)diederik Wrote:
(03-15-2023, 07:29 AM)mburns Wrote:
(03-14-2023, 07:18 AM)diederik Wrote:
(03-09-2023, 03:46 PM)mburns Wrote: There is now a held back version of the Mobian pinephonepro-support package that is necessary for a working network connection. So users can not update Mobian until that package is not held back. This is as of Thursday afternoon, March 9.
https://blog.mobian.org/posts/2023/03/11...-firmware/
Actually, a distribution should automate this kind of transition, before wifi is lost. Everyday an updated installation is not functional, a fraction of users would be lost.
Agreed, but this caused by an unfortunately set of circumstances:
- Mobian is actually Debian + Mobian, so actually 2 distros combined into 1
- Debian made a change in non-free-firmware which collided with a 'patch' that Mobian had, while unaware that Mobian had that
- So Mobian dropped their patch and switched to the Debian package, but the change wrt the non-free-firmware archive area hadn't been communicated yet
A new archive area (non-free-firmware) is something that rarely happens, so chances of that happening again are really slim.
There's now better collaboration/coordination between Debian and Mobian to (hopefully) prevent such things from happening again.
When a transition needs to happen within Debian, that is automatically handled. But such things don't work (automatically) across distros.
HTH
The explanation is appreciated. But my copy of Mobian is now on the smaller and slower chip for the time being.
I had an image file which fit the size of the chip, so a command like this worked to reinstall Mobian on the chip that was inserted into a Linux computer.
# umount /dev/sdb1
# umount /dev/sdb2
# dd if=Mobian.img of=/dev/sdb bs=4M
# sync; sync
If the image does not fit, then the Linux tools are needed to resize the /dev/sdb2 partition after the copy.
Rebooting Mobian to get AV playback is mostly no longer needed.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 15 1,903 1 hour ago
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,257 02-13-2024, 02:54 PM
Last Post: fxc
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,582 12-26-2023, 02:14 PM
Last Post: apink
  Disable the GDM service in Mobian. mburns 0 471 11-25-2023, 10:19 PM
Last Post: mburns
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 848 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 980 11-23-2023, 08:39 AM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 894 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 504 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 715 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 607 10-14-2023, 11:57 AM
Last Post: mburns
