Can't call or receive calls
I've had my PinePhone for quite a while, but only recently got a SIM for it. Calling and receiving calls is not working, I was told to change from ofono to ModemManager with this command:
sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager
Terminal accepted the command, but calling and receiving calls still doesn't work. Oddly when calling the PinePhone the screen will briefly dim in sync with each call ring heard in the calling phone.
In the GUI settings looks like this:
SIM 0 - SIM Details
Operator Name - T-Mobile
Modem Details
Enabled - true
State - Disabled
Failure Reason - No error
This is the standard PinePhone current edition shipping stock with Manjaro.
I have partially solved the problem by downloading and flashing the current OS file. Now the Pinephone will make a call and rings when there is an incoming call, but nothing happens when I press "Accept" for an incoming call.
(04-25-2022, 09:26 PM)PJK2012 Wrote: I have partially solved the problem by downloading and flashing the current OS file. Now the Pinephone will make a call and rings when there is an incoming call, but nothing happens when I press "Accept" for an incoming call.
Known issue: https://gitlab.manjaro.org/manjaro-arm/i...issues/205
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
Thanks for these resources.
(04-26-2022, 03:12 AM)acrux Wrote: Known issue: https://gitlab.manjaro.org/manjaro-arm/i...issues/205
After a few reboots the behavior has gotten more in line with the gitlab issue reports. If the phone is with screen off, it will ring, but pressing accept to answer won't work until I unlock the phone. On the other hand, leaving the screen on with the phone unlocked, the phone doesn't ring, but I can accept a call. So this proves all functions work, just not consistently. So I am marking this thread solved.
  Calls/Texts and External Monitor gregb49 0 3,035 06-30-2023, 11:38 AM
Last Post: gregb49
  Internal Microphone issue during calls Viktor 6 8,205 03-31-2023, 08:58 AM
Last Post: Viktor
  Unable to hear caller or speak after answering a call danimations 5 8,523 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  Weird call... Eugo 3 5,616 09-15-2022, 11:20 PM
Last Post: Eugo
  New issue with phone calls kmsgli 13 17,852 08-15-2022, 01:45 PM
Last Post: Gon
  Pinephone craches after each call neithan76 2 4,160 07-29-2022, 11:47 AM
Last Post: Chief
  Call waiting issue kmsgli 22 32,318 06-24-2022, 06:02 PM
Last Post: kmsgli
  Calls & SMS stopped working Schugy 3 5,099 12-28-2021, 05:00 AM
Last Post: Schugy
  phonebook app does not send sms or voice call tckosvic 13 18,525 12-19-2021, 07:12 PM
Last Post: tckosvic
  No incoming SMS. Outgoing SMS, calls and data working. HardwarePunk 3 6,523 11-20-2021, 12:53 AM
Last Post: HardwarePunk
