troubleshooting Chatty / modem? no SMS outbound
UPDATE:
I got SMS outbound working.  I had indeed fat fingered an recommended re-config, but for the benefit of anyone on a troublesome carrier, here's what it is:
Copy the Quectel modem daemon config to prevent updates from overriding:
sudo cp /usr/share/eg25-manager/pine64,pinephone-1.2.toml /etc/eg25-manager/
NOTE: there's several of these TOML files under /usr/share so copy the specific version of phone you have. I have a PPv1.2.
Reconfigure the modem to _disable_ IMS over 4G:
{ cmd = "QCFG", subcmd = "ims", value = "2" },
WARN: that ^ was where I'd fat fingered an earlier test.  The default config is '..., expect = "1"' and I had accidentally fat fingered to '..., expect = "2"'.  Notice 'expect' versus 'value'.
NOTE: this eg25-manager (Quectel modem "manager") has _nothing_ to do with ModemManager.  I had tried some reconfigs in ModemManager's configs (via NetworkManager) based on other suggestions but they had no affect on SMS issues. Also, there's no Chatty config that should affect plain txt SMS; just MMS, so I should probably change the subject? Testing via 'mmcli [...] -s [N] --send' makes that more clear.
Reboot and SMS outbound now works on USMobile.
Evidently this IMS setting has caused forum member's SMS frustration in the past: https://forum.pine64.org/showthread.php?...#pid101233
RE: troubleshooting Chatty / modem? no SMS outbound - by vap0rtranz - 02-14-2022, 12:15 PM
  Modem white list aular 7 1,136 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 1,097 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,182 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 1,917 03-27-2023, 02:51 AM
Last Post: jojuma
  Troubleshooting and Understanding MMS epiii2 74 38,123 02-16-2023, 11:29 AM
Last Post: npesall
  Modem audio settings jack1 2 1,376 02-04-2023, 04:01 PM
Last Post: jack1
  The modem switch affects the connection to battery? JohnDoe 2 2,123 03-30-2022, 12:02 AM
Last Post: JohnDoe
  Modem disabled, can't enable: Invalid transition pac 4 3,712 03-23-2022, 01:08 PM
Last Post: Firewave
Question Modem problems with the distros I tried UltraBlack_ 9 5,493 02-21-2022, 01:57 PM
Last Post: KNERD
  PinePhone Beta 3GB modem not working hannescam 15 9,397 01-19-2022, 02:08 AM
Last Post: bcnaz
