can no longer make or receive calls or SMS
plasma development branch. After flashing the most recent image 2 days ago, the phone will no longer make or receive calls or send SMS. It's odd, because prior to that, it was working more or less normally (except for the usual intermittent lose-the-modem flakiness). Although the indicator shows bars and says I am connected to the cellular network, it remains inaccessible. Updated as of 10 minutes ago, same problem. Rebooting does not help.
I've tried restarting ofonoctl, with no change in behavior. Any suggestions that could work me out of this?
Thanks.
(06-29-2021, 11:03 AM)Athansor Wrote: I've tried restarting ofonoctl, with no change in behavior. Any suggestions that could work me out of this?
Thanks.
I've been finding that my modem just disappears occasionally, every day or so.  To fix it I have to type in:
sudo systemctl restart ofono
sudo systemctl restart eg25-manager
ofonoctl poweron
ofonoctl online
I wonder if typing ofonoctl online in the terminal would get you back in business?
plasma-dialer was updated yesterday and now works again, update from terminal with `sudo pacman -Syu`
(06-29-2021, 07:49 PM)mouffa Wrote: plasma-dialer was updated yesterday and now works again, update from terminal with `sudo pacman -Syu`
I tried that and it said everything was up to date yet I can't make or receive texts/calls either...
I can't say much, Plasma Dialer is old and very poorly maintained and though the phone functionality is very important nobody cares to develop a good application, it is basically a front-end to Telepathy and ofono, I just tested it and tough it makes calls you can only here white noise from the speaker, the behaviour may be different depending on the device and the mobile operator, just use a burner phone for the moment and test it after some days again.
try to make some calls with the qdbus commands
`qdbus --system org.ofono /quecteqmi_0 org.ofono.VoiceCallManager.Dial call_number "" `
and hang up with
`qdbus --system org.ofono /quecteqmi_0 org.ofono.VoiceCallManager.HangupAll`
  Calls/Texts and External Monitor gregb49 0 3,276 06-30-2023, 11:38 AM
Last Post: gregb49
  Internal Microphone issue during calls Viktor 6 8,812 03-31-2023, 08:58 AM
Last Post: Viktor
  New issue with phone calls kmsgli 13 18,973 08-15-2022, 01:45 PM
Last Post: Gon
  Can't call or receive calls PJK2012 3 7,300 04-26-2022, 03:05 PM
Last Post: PJK2012
  Calls & SMS stopped working Schugy 3 5,445 12-28-2021, 05:00 AM
Last Post: Schugy
  No incoming SMS. Outgoing SMS, calls and data working. HardwarePunk 3 6,851 11-20-2021, 12:53 AM
Last Post: HardwarePunk
  After fresh install outbound phone calls not working. tckosvic 2 5,203 11-10-2021, 10:45 AM
Last Post: tckosvic
  Issue with Calls on Phosh Barugon 4 7,695 10-15-2021, 05:46 AM
Last Post: Johnmash2
Question SIP on Calls app ? zeb11 1 3,975 07-16-2021, 05:22 AM
Last Post: Codenul
Brick Can send SMS but can't receive SMS with Beta 11..? Please help danimations 3 6,676 07-13-2021, 04:57 AM
Last Post: danimations
