debian fresh install 5/14
fresh install, everything was fine installing SSH and VNC4Server
Reboot
Now it just hangs after the initial linux boot on the second black screen a the line for sunni-gmac 1c30000.eth eth0:  .......
hoping to not have to wipe the SD and start over, but after reading a few posts, I'm wondering if someone with more knowledge might be able to shed some light?
(05-15-2016, 06:10 PM)mkyb14 Wrote: fresh install, everything was fine installing SSH and VNC4Server
Reboot
I'm not sure if this will help, but I read on another thread that the hang might be due to not having an Ethernet cable plugged in--the OS is waiting for the lengthy timeout it has if there's no connection. If one waits long enough it should resume loading.
How long did you wait. It can take like 5 minutes to boot as it waits for Ethernet. Your best bet is to plug in an Ethernet cable. As an FYI, used the Debian image just this morning and it went smoothly, but my first boot had the Ethernet cable plugged in.
nope, nothing has worked. plugged in or not, I've let it sit for more than a day and it will not finishing booting. At this point i'll re-install again, but if this happens again there's got to be some support from the pine crew for what we are seeing with Eth0 issues in the forums.
Thanks guys.
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,271 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,881 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,695 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 17,204 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 167,539 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,587 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Digital drawing tablet Huion - proper drivers install janeku 20 47,625 05-19-2019, 09:24 PM
Last Post: xinhua
  Script to build pure Debian images for Pine64+ amp 1 7,944 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,320 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,509 03-29-2019, 02:00 AM
Last Post: desai_amogh
