Unable to initialize message in chatty
When I click on + to choose one of my contacts in chats (chatty) . Chats never initializes a chat dialog but instead goes back to the main choose a contact screen again. If someone texts me first it works just fine. I'm just unable to start a chat myself.
I think this is a known issue.
Try prepending the country code (+xx) when starting a new chat and/or change your contacts to include the country code.
That did it. Thanks very much.
(06-28-2020, 01:54 AM)devrtz Wrote: I think this is a known issue.
Last time i tried to Dial a contact that had +xx in the GSM number , the dialing failed.
Has that been fixed or ??
I mean since the suggestion of prepending the +xx countrycode ?
/Bingo
All my contacts have the country code in front of them and I can call them (both from the contacts window and the history).
And I've also just tried calling a number (dialing manually) with the countrycode, which worked just fine.
(06-29-2020, 01:38 PM)devrtz Wrote: All my contacts have the country code in front of them and I can call them (both from the contacts window and the history).
I have no issues making and receiving calls or SMS but I cannot do either from contacts. Clicking the chat or call buttons registers nothing for me.
Do your contacts have the country code prefix?
No. Not all of them. Maybe something corrupt during the import process? I imported them via my Google account. But, I added the country code (1) to 6 of them and the manually created a contact but still nothing happens when attempting to initialize a chat or call from Contacts. Only numbers come up in the caller ID for both chat's and calls.
Is there a way to wipe all contacts and then import them through vcf?
Not 100% sure, but I think contacts (and calendar afaik) is stored in ~/.local/share/evolution.
You could try wiping it (and maybe restart the phone because some apps might still have the contacts cached) and then try to reimport it and reboot again.
(07-06-2020, 08:25 AM)devrtz Wrote: Not 100% sure, but I think contacts (and calendar afaik) is stored in ~/.local/share/evolution.
I have not tried 'importing' my contacts.
I entered every contact manually through the GUI and they do just work that way.
The incoming text is recognized and it posts the name who is texting,  however on incoming phone calls, it does not show the callers name.
  ( July 03 nightly build )
  Could not initialize OpenGL support jojuma 6 11,260 09-14-2024, 12:06 PM
  Unable to wake up from suspend xavi92 6 7,649 07-28-2024, 02:48 PM
Last Post: dchang0
  Chatty Matrix Decryption Key jojuma 2 3,720 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 4,159 11-12-2023, 02:10 AM
Last Post: user641
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,498 09-01-2023, 11:29 AM
Last Post: Mahgue
  Chatty does not work after suspend mode user641 4 7,168 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,259 07-07-2023, 03:29 AM
Last Post: jojuma
  beware chatty 0.7.0~rc0-1 treebeard 6 8,264 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 11,992 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 2,380 09-07-2022, 04:35 AM
Last Post: user641
