04-06-2021, 11:43 AM
GloDroid (Android-13)
04-08-2021, 07:38 AM
(04-06-2021, 11:43 AM)nas Wrote:(04-06-2021, 08:23 AM)layton-dev Wrote: Hi ! I'm currently using Glodroid v0.5.1 on the Pinephone, I'm wondering if TrustyOS is supported on this device ? I see, thank you for your reply !
GloDroid 0.6.1 has been released recently: https://github.com/GloDroid/glodroid_man...tag/v0.6.1
I hope to find the time to make a quick install guide video for the SD card install next week to draw some attention to the project. Edit: Here it is!
Coincidentally, I also did a tutorial on installing GloDroid almost at the same time as linmob.
Here is the link: https://www.youtube.com/watch?v=uwgUVXuP18E
07-03-2021, 10:56 AM
Just wanted to chime in; I set up GloDroid on an SD card for my pinephone last night, and it feels like so much progress has been made. I haven't put a SIM card in it to test phone calls or data usage, but every-day usage like browsing the internet on Firefox or installing whatever from F-Droid feels so natural, and it just works!
It's amazing how well this device runs with software that was made for phones. As excited as I am for other prospects like Manjaro+Plasma Mobile, this is far and away the most pleasant to use experience on my pinephone right now in 2021. It's actually so smooth I gotta wonder; Is Glodroid using full hardware acceleration with the mali400 GPU in the pinephone?
07-03-2021, 11:00 AM
(07-03-2021, 10:56 AM)gamerminstrel Wrote: Just wanted to chime in; I set up GloDroid on an SD card for my pinephone last night, and it feels like so much progress has been made. I haven't put a SIM card in it to test phone calls or data usage, but every-day usage like browsing the internet on Firefox or installing whatever from F-Droid feels so natural, and it just works!It feels buttery smooth sometimes, but when I tried installing a camera application, the cameras will not work. Also, I heard phone features do not work yet.
07-12-2021, 10:06 AM
Hello all,
I Installed the 0.6.1 version into eMMC using the guide in (https://youtu.be/WbqzMXsnEEA) and it runs perfectly smooth. Going through the menus is easy and fast, amazing. Installed Firefox works very well, use F-droid to install anything, Newpipe needs a second to start and is fine, sound is good but low volume, screen is very stable all around. A few comments: - Missing phone operation (this is important ;- Wifi has glitches (^goes off and to reconnect switching off and on again is necessary); - BT works (was able to transfer a file between androids); - Name of device goes back to stock after reboot; - No Headphones; - No lockscreen (pin security or password); - No camera; - No GPS?; - VLC could not play a 1080 video downloaded using Newpipe. - Build update through flash only(is this correct?; Very good work, keep it up!!
07-13-2021, 08:33 AM
This is a super small thing I noticed, but it feels like the built-in speaker is not being used to its full potential. Yea its not a great speaker, but I can barely hear audio at max volume. Wouldn't even be an issue if I could use the headphone jack.
10-22-2021, 03:27 PM
(07-09-2020, 12:22 PM)rsglobal Wrote: GloDroid (AOSP for the world's most accessible development platforms)Does anyone know what the Authentication password for it? Thank You Chris
10-28-2021, 10:39 AM
Is there a way like OTA updates to update GloDroid/Android itself without turning the device off and reflashing the entire system? It feels a bit less than ideal to basically factory reset to see how the latest update works.
| GloDroid (Android-14) | GaryM | 1 | 6,114 |
04-17-2024, 08:39 AM Last Post: GaryM |
Android Auto on Pinephone via Waydroid: a pipe dream? | slondr | 1 | 5,347 |
11-06-2022, 01:46 PM Last Post: wibble |
| difference between android and linux? | vanja | 3 | 5,681 |
09-16-2022, 07:43 PM Last Post: TRS-80 |
| Android and Google Play Store on a PinePhone? | Solra Bizna | 22 | 60,100 |
11-01-2021, 07:11 AM Last Post: digitalmouse |
| Easiest way to use Android applications on Pinephone | esud | 4 | 15,583 |
06-21-2021, 04:52 AM Last Post: vanja |
| Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) | 4w7gvrvsjcyvd | 0 | 3,302 |
01-30-2021, 06:48 PM Last Post: 4w7gvrvsjcyvd |
| pine phone came with android? | andrewiassur | 1 | 5,224 |
04-11-2020, 02:06 PM Last Post: fire219 |
