Pinebook Pro dead after dd
Exclamation
I booted my Pinebook Pro with a microSD card running Mankato and used it to download an image to flash to my EMMC, after doing so I shut it down and noticed the charging LED would turn off after about a 30 seconds I tried turning it on and was met with nothing, no power led on the top of the keyboard and no light from the barrel connector. I opened the back and hit the reset button but to no avail, I unplugged the battery, removed and disabled EMMC, tried using usb c to charge but still nothing. Any help would be greatly appreciated
Edit: Got it to boot from microSD however I’m greeted with “give root password for maintenance or press control D to skip, pressing control D reads cannot read /dev/tty1 and it hangs. Any advice?
Well, it sounds like the simplest thing to do is write a new image to micro SD, boot to that, then rewrite the eMMC.
For the first week of owning PBP, I wasn't pushing the power adapter all the way in. I've learnt the hard ways, to avoid excessive force with electronics, and so I inserted the power adapter till snug, and it powered on -- but I had occasional screen flickerings and battery charging issues, until I learned that, in this case, with just a little more force, the adapter snaps all the way in, with no shiny metal visible.
The screen you received about giving root password for maintenance is common when a device loses power suddenly (like when battery runs out) and doesn't have time to shutdown properly, causing corrupted filesystems. After you give the root password, you can run e2fsck and repair corrupted file systems before hitting cntrl-d.
Since you were noticing the charging light and having the error I get from power failures, perhaps all you have to do is exert a little more force when plugging in your power adapter until you feel it snap into position.
  Updated Pinebook Pro? tantamount 2 2,600 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,363 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,948 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,618 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,073 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,002 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,143 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,021 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,378 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 30,389 03-09-2025, 11:17 AM
Last Post: davisthomas
