Anyone have a microphone working on a Pinebook Pro?
I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro?
(02-12-2021, 06:46 AM)Rachel Stone Wrote: I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro?
You are in the wrong section. This area is for the PinePhone. Might want to move this to the Pinebook Pro section.
View my projects at: https://gitlab.com/users/The3DmaN/projects or at the3dman.gitlab.io you can also find me on Matrix in many of the Pine related channels.
@The3DmaN Thread moved.
@Rachel Stone You might want to check the privacy switch for the microphone:
Wiki - Pinebook Pro - Privacy Switches
Arwen Evenstar
Princess of Rivendale
The keyboard firmware really ought to expose these switches over USB. They can be read only. That way it can show up that there microphone is disabled via privacy switch, instead of just mysteriously not working.
And put something on the keyboard markings about the functionality!
@xyzzy I made the suggestion to Jack for his keyboard firmware;
https://github.com/jackhumbert/pinebook-.../issues/10
It's not implemented, yet?.
Arwen Evenstar
Exporting that information would be neat, which could even be done through another, separate USB endpoint, but I think that the reverse engineering of the keyboard firmware requires a lot more work before something like that could be done.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,758 10-05-2026, 12:42 PM
  Replacement battery for PineBook Pro DrYak 5 9,514 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,176 03-23-2025, 03:31 PM
Last Post: WEF
  New Working nVME gilwood 1 4,485 11-17-2024, 04:24 AM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 5,776 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,967 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,023 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,977 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 239,099 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 15,619 01-18-2023, 07:41 PM
Last Post: ottahe
