02-12-2021, 06:46 AM
I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro?
Anyone have a microphone working on a Pinebook Pro?
02-12-2021, 08:54 AM
(02-12-2021, 06:46 AM)Rachel Stone Wrote: I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro? You are in the wrong section. This area is for the PinePhone. Might want to move this to the Pinebook Pro section.
View my projects at: https://gitlab.com/users/The3DmaN/projects or at the3dman.gitlab.io you can also find me on Matrix in many of the Pine related channels.
02-12-2021, 09:17 AM
@The3DmaN Thread moved.
@Rachel Stone You might want to check the privacy switch for the microphone: Wiki - Pinebook Pro - Privacy Switches
Arwen Evenstar Princess of Rivendale
The keyboard firmware really ought to expose these switches over USB. They can be read only. That way it can show up that there microphone is disabled via privacy switch, instead of just mysteriously not working.
And put something on the keyboard markings about the functionality!
02-14-2021, 11:00 AM
@xyzzy I made the suggestion to Jack for his keyboard firmware;
https://github.com/jackhumbert/pinebook-.../issues/10 It's not implemented, yet?.
02-20-2021, 05:21 AM
Exporting that information would be neat, which could even be done through another, separate USB endpoint, but I think that the reverse engineering of the keyboard firmware requires a lot more work before something like that could be done.
| HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? | segaloco | 8 | 11,380 |
11-17-2026, 12:39 AM Last Post: NorrisFByrd |
| Replacement battery for PineBook Pro | DrYak | 5 | 9,852 |
02-28-2026, 09:17 PM Last Post: KC9UDX |
| pinebook pro dixplays vertical stripes | WEF | 2 | 5,379 |
03-23-2025, 03:31 PM Last Post: WEF |
| New Working nVME | gilwood | 1 | 4,703 |
11-17-2024, 04:24 AM Last Post: reukiodo |
| Yet another new Pinebook keyboard problem | MikoBob | 3 | 5,977 |
09-11-2024, 07:05 AM Last Post: MikoBob |
| Pinebook Pro on Debian 12 Power Issue | u974615 | 1 | 5,153 |
03-13-2024, 10:46 AM Last Post: u974615 |
| Pinebook Pro Source for Trackpad Flex / Ribbon Cable | rankharris | 1 | 5,228 |
02-17-2024, 07:06 PM Last Post: tllim |
| Pinebook Pro charging issues | tomekdev | 1 | 4,120 |
01-05-2024, 08:40 PM Last Post: tomekdev |
| Pinebook Pro Revised Keyboard Firmware | jackhumbert | 73 | 241,909 |
09-13-2023, 03:43 AM Last Post: k3dAR |
| PineBook Pro dead | ottahe | 9 | 15,851 |
01-18-2023, 07:41 PM Last Post: ottahe |
