Axolotl on PinePhone / Mobian
(12-07-2020, 03:03 AM)marcih Wrote:
(12-06-2020, 01:49 PM)arno_nuehm Wrote:
(11-18-2020, 02:38 PM)marcih Wrote:
(11-17-2020, 11:51 AM)arno_nuehm Wrote:
(11-16-2020, 07:05 AM)marcih Wrote: Lucky you, I can't even get it to build, it always freezes at "npm install" when it's installing(?) node's rxjs. Has anybody gotten it to build successfully recently?
Is it really a "freeze" or is it just taking a bit more time? In my case (around 04.11.2020 - same date for the Mobian nightly image) it took quite a while for "npm install" to finish.
I'm not quite sure, I left it alone for half an hour or so with no progress, I assumed it was frozen since the little spinning line on the left wasn't moving either. I'll give it a try again tomorrow, leave it be for longer.
Have you tried it? I will have a go with a fresh installation of the fde-image in a few days and give you an update...
I have, with no luck. Interestingly, building the Flatpak went through fine so I don't know what the issue is. Either way, the app is currently not functional anyway, Electron crashes and qmlscene is not bundled in the Flatpak and doesn't seem to recognise the apt-installed copy.
With electron there is a known issues on arm64/aarch64 devices, I think. And Axolotl with qmlscene isn't working for me, too, I'm using it with the server flag and Firefox-esr as frontend. It's a work-around, but it works quite fine.
In a few days, I will try a fresh installation of Mobian/Axolotl and look into the qmlscene issues as well. Let's hope for the best.
(12-07-2020, 04:20 AM)arno_nuehm Wrote:
(12-07-2020, 03:03 AM)marcih Wrote: I have, with no luck. Interestingly, building the Flatpak went through fine so I don't know what the issue is. Either way, the app is currently not functional anyway, Electron crashes and qmlscene is not bundled in the Flatpak and doesn't seem to recognise the apt-installed copy.
Oh oops, I forgot to add the link to the GitHub issue regarding the Electron crash in my last post. It seems that there has been some activity in the aforementioned report as well, a new PR for adding a "-e qml" option which should work with Flatpak. I tried using firefox-esr as well, I could get as far as entering the verification code sent to my phone but FF crashed at that point so I gave up and I'm now waiting for either Electron or QML to work on Mobian. As soon as the PR gets merged, I'll rebuild and see what happens when I try to run the Flatpak. Wink
Thanks for the update!
Axolotl 0.9.0.1 is now running with qmlscene on the latest fde-image (20201215). I updated the Mobian Wiki - Manual install.
The registration process is still tricky. If it fails, use the following lines to get a clean start
rm ~/.cache/QtProject/QtQmlViewer/qmlcache/* && rm -r ~/.local/share/textsecure.nanuc && rm -r ~/.config/textsecure.nanuc
And a restart of Mobian is also helpful. Also, Axolotl has some known registration issues.
Let me know, if your registration worked. I didn't want to de-link my desktop app and tried several online burner numbers. The code was sent but in the end, I used my backup folders.
Update: From time to time, Axolotl is not starting correctly. Clearing the above mentioned qmlcache folder helps.
Hi everyone.  I got my new Pinephone last Friday and have been trying to get Axolotl installed for a few days now.  I tried following arno's post from 12/16, but it's not quite working.
I installed mobian-installer-pinephone-phosh-alpha3.img and then followed the steps on the mobian wiki.
qt / qml interface
sudo apt install flatpak flatpak-builder
flatpak install org.kde.Platform//5.15
flatpak install org.kde.Sdk//5.15
flatpak install org.freedesktop.Sdk.Extension.golang//20.08
flatpak install org.freedesktop.Sdk.Extension.node12//20.08
flatpak install io.qt.qtwebengine.BaseApp//5.15
wget https://raw.githubusercontent.com/nanu-c...xolotl.yml
sudo flatpak-builder --install build org.nanuc.Axolotl.yml
Everything seemed to work properly.
However, when I tap the Axolotl icon, nothing happens. I just get the background screen.
Trying to run the cache clearing script
I get the message that so such directory exists at home/mobian/.cache/QtProject/QtQmlViewer/qmlcache
I'm sure there's something obvious I'm missing.
Any help is appreciated, thanks.
(12-21-2020, 02:00 PM)acm006 Wrote: Hi everyone.  I got my new Pinephone last Friday and have been trying to get Axolotl installed for a few days now.  I tried following arno's post from 12/16, but it's not quite working.
qt / qml interface
I had the same issue, there is an issue open on Axolotl Github that I think is related (see. https://github.com/nanu-c/axolotl/issues/289) regarding flatpak file paths. I found a quick fix by making my own desktop icon as shown below. Axolot sometime fails to start the first time but otherwise has been working fairly well for me.
sudo nano /usr/share/applications/axolotl.desktop
[Desktop Entry]
Type=Application
Name=Axolotl2
GenericName=Signal Chat Client
Exec=flatpak run org.nanuc.Axolotl -e=qt
Icon=/home/mobian/build/files/share/icons/hicolor/128x128/apps/org.nanuc.Axolotl.png
Terminal=false
Categories=Network;Chat;InstantMessaging;Qt;
StartupWMClass=axolotl
qt / qml interface
[Desktop Entry]
Type=Application
Name=Axolotl2
Terminal=false
Hello there,
I described the situation for manual installation not using flatpak-builder so the paths are a bit different. But I have the same issues with -e qt as described by acm006. Sometimes the app starts and sometimes it fails.
It may be related to the main .qml file which produces some error messages. Have a look here: Link.
For me, the deamonized option is still the best way to use Axolotl - regardless of the building process.
And my future idea is to have the deamon running and start the UI with qmlscene separately if needed. Good on resources...
(12-16-2020, 07:06 PM)arno_nuehm Wrote: ...
 I have just followed the steps under "Manual install" with no major problems (BTW npm install ran about 25 minutes) until
mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$ npm run build > axolotl-web@0.1.0 build > vue-cli-service build ⠹  Building for production... ERROR  Failed to compile with 3 errors        22:09:47 error  in ./src/assets/dark.scss Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js): ModuleBuildError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js): Error: Node Sass does not yet support your current environment: Linux Unsupported architecture (arm64) with Node.js 12.x For more information on which environments are supported please see: https://github.com/sass/node-sass/releases/tag/v4.14.1     at module.exports (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/binding.js:13:13)     at Object.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/index.js:14:35)     at Module._compile (internal/modules/cjs/loader.js:999:30)     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)     at Module.load (internal/modules/cjs/loader.js:863:32)     at Function.Module._load (internal/modules/cjs/loader.js:708:14)     at Module.require (internal/modules/cjs/loader.js:887:19)     at require (internal/modules/cjs/helpers.js:74:18)     at getDefaultSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getDefaultSassImplementation.js:24:10)     at getSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getSassImplementation.js:19:72)     at Object.loader (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/index.js:40:61)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/webpack/lib/NormalModule.js:316:20     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:367:11     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:233:18     at runSyncOrAsync (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:143:3)     at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:232:2)     at Array.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:205:4)     at Storage.finished (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:55:16)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:91:9     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/graceful-fs/graceful-fs.js:115:16     at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3) @ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/App.vue?vue&type=script&lang=js& 33:2-30 @ ./src/App.vue?vue&type=script&lang=js& @ ./src/App.vue @ ./src/main.js @ multi ./src/main.js error  in ./src/assets/light.scss Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js): ModuleBuildError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js): Error: Node Sass does not yet support your current environment: Linux Unsupported architecture (arm64) with Node.js 12.x For more information on which environments are supported please see: https://github.com/sass/node-sass/releases/tag/v4.14.1     at module.exports (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/binding.js:13:13)     at Object.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/index.js:14:35)     at Module._compile (internal/modules/cjs/loader.js:999:30)     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)     at Module.load (internal/modules/cjs/loader.js:863:32)     at Function.Module._load (internal/modules/cjs/loader.js:708:14)     at Module.require (internal/modules/cjs/loader.js:887:19)     at require (internal/modules/cjs/helpers.js:74:18)     at getDefaultSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getDefaultSassImplementation.js:24:10)     at getSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getSassImplementation.js:19:72)     at Object.loader (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/index.js:40:61)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/webpack/lib/NormalModule.js:316:20     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:367:11     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:233:18     at runSyncOrAsync (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:143:3)     at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:232:2)     at Array.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:205:4)     at Storage.finished (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:55:16)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:91:9     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/graceful-fs/graceful-fs.js:115:16     at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3) @ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/App.vue?vue&type=script&lang=js& 35:2-31 @ ./src/App.vue?vue&type=script&lang=js& @ ./src/App.vue @ ./src/main.js @ multi ./src/main.js error  in ./src/components/Message.vue?vue&type=style&index=0&id=b1b7f866&lang=scss&scoped=true& Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js): ModuleBuildError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js): Error: Node Sass does not yet support your current environment: Linux Unsupported architecture (arm64) with Node.js 12.x For more information on which environments are supported please see: https://github.com/sass/node-sass/releases/tag/v4.14.1     at module.exports (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/binding.js:13:13)     at Object.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/index.js:14:35)     at Module._compile (internal/modules/cjs/loader.js:999:30)     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)     at Module.load (internal/modules/cjs/loader.js:863:32)     at Function.Module._load (internal/modules/cjs/loader.js:708:14)     at Module.require (internal/modules/cjs/loader.js:887:19)     at require (internal/modules/cjs/helpers.js:74:18)     at getDefaultSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getDefaultSassImplementation.js:24:10)     at getSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getSassImplementation.js:19:72)     at Object.loader (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/index.js:40:61)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/webpack/lib/NormalModule.js:316:20     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:367:11     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:233:18     at runSyncOrAsync (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:143:3)     at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:232:2)     at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:221:10)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:236:3     at context.callback (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:111:13)     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/cache-loader/dist/index.js:147:7     at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/graceful-fs/graceful-fs.js:57:14     at FSReqCallback.oncomplete (fs.js:156:23) @ ./src/components/Message.vue?vue&type=style&index=0&id=b1b7f866&lang=scss&scoped=true& 1:0-532 1:548-551 1:553-1082 1:553-1082 @ ./src/components/Message.vue @ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/pages/MessageList.vue?vue&type=script&lang=js& @ ./src/pages/MessageList.vue?vue&type=script&lang=js& @ ./src/pages/MessageList.vue @ ./src/router/router.js @ ./src/main.js @ multi ./src/main.js ERROR  Build failed with errors. npm ERR! code 1 npm ERR! path /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web npm ERR! command failed npm ERR! command sh -c vue-cli-service build npm ERR! A complete log of this run can be found in: npm ERR!    /home/mobian/.npm/_logs/2021-01-19T22_09_48_338Z-debug.log mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$
I absolutely haven't a clue what I am doing - I am merely following the recipe, so any suggestions welcome!
TIA
Previous step seems to have been fine:
mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$ npm install added 1753 packages, and audited 1820 packages in 25m 7 packages are looking for funding   run `npm fund` for details 1 low severity vulnerability To address all issues, run:   npm audit fix Run `npm audit` for details. mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$
Having a similar issue when opening axolotl:
ERRO[0001] '/home/mobian/snap/axolotl/210/vendor/electron-linux-arm64/electron' exited with code: 1
TIA
Hello there,
I tested the manual install of Axolotl 0.9.4 with a fresh Mobian (FDE-Installer 20201215) and all the latest updates. And I got the same error message at
npm run build
I will post an issue on github tomorrow; hopefully 0.9.5 fixes that. I'm still running 0.9.0.1 on my daily driver...
Cheers
  Mobian MMS/SMS text problem bcnaz 16 40,086 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,724 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,621 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,841 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,191 02-20-2025, 02:47 PM
Last Post: puffchumpy
Users browsing this thread: 7 Guest(s)
