UBOOT - Mainline not booting from SD card / BSP OK
Hi!
I played a little bit with both version of UBOOT avilable in PACMAN in Manjaro 20.10.
Aside the fact that is you don't backup your extlinux.conf file you my end with an unbootable computer, I found that :
- When using the "mainline" (uboot-pinebookpro) version, booting from SD card don't works
- When using the "bsp" (uboot-pinebookpro-bsp) version, booting from SD card works
It is a normal behavior or is there something wrong in the way I flash the UBOOT?
Here is how i switch between both (on my eMMC)
For MAINLINE I do :
pacman -S uboot-pinebookpro dd if=/boot/idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc,fsync dd if=/boot/u-boot.itb of=/dev/mmcblk2 seek=16384 conv=notrunc,fsync cp /boot/extlinux/extlinux.conf.sav /boot/extlinux/extlinux.conf rm /boot/extlinux/*.pacnew
For BSP I do :
pacman -S uboot-pinebookpro-bsp dd if=/boot/idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc dd if=/boot/uboot.img of=/dev/mmcblk2 seek=16384 conv=notrunc dd if=/boot/trust.img of=/dev/mmcblk2 seek=24576 conv=notrunc cp /boot/extlinux/extlinux.conf.sav /boot/extlinux/extlinux.conf rm /boot/extlinux/*.pacnew
Thanks!
A full re installation from SD card to eMMC (with mainline U-Boot) works as expected.
I suppose that when switching u-boot version between mainline/bsp version would be better if writing zeroes to destination drive first or something like that. Anyway, case closed!
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,411 03-10-2025, 01:55 PM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,664 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,490 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 3,388 08-18-2023, 01:58 AM
Last Post: juliamenendez
  2TB SD Card Write Errors jiacovelli 3 4,427 06-02-2023, 06:13 PM
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 13,940 04-01-2023, 02:58 PM
Last Post: TRS-80
  Bootloader: SD card boot quirks crazyquark 1 3,339 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 16,634 09-27-2022, 01:45 PM
Last Post: myself600
  Booting Arch from USB lorebett 6 9,201 09-18-2022, 11:35 AM
Last Post: lorebett
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 29,849 08-18-2022, 11:26 PM
Last Post: calinb
