openSUSE for Pinephone
#31
Now i am working in features like improving battery and bluetooth.
Moreover for next release i think also we can have improvement in FPS (from megi's patches) and new kernel version (5.9)
Looking forward into testing this... let's hope my PinePhone arrives soon so I can start testing around.
I have a couple question about this port, though:
-Which software components are non-FOSS?
-Is YaST included (or at least the software management tools)?
-How is the battery life doing right now?
(11-04-2020, 01:39 PM)andresbs Wrote: Looking forward into testing this... let's hope my PinePhone arrives soon so I can start testing around.
For the first question, all software components arre FOSS, then you can install everything with "zypper install" or whatever command you use with opensuse OS, Yast2 gui are not well adapted for mobile UI so it disabled by default, you can install it and test it if you want.
Battery life i think is worst part for now, maybe 1 working day without using it a lot, maybe 5-6 hours using it continuosly.
## 2020.16.11
Add bootsplash for boot and shutdown
**Implemented enhancements:**
- Add bootsplash
- Fix kernel start (laggy bug)
- Fix audio problems in calls
- Added gnome-initial-setup to add language to your on-screen keyboard
- Fix problem changing between on-screen keyboard and emoji keyboard
- Change Pinhole for Megapixels for camera app
- Patched kernel with fixes for brightness
- Fix problem with modem in last release
- Now bluetooth are working correctly
**Working:**
- Calls (Auto-switch audio profiles)
- SMS
- Mobile Data
- WiFi
- Front Camera (laggy)
- Back Camera (laggy)
- Touchscreen
- Brightness
- Sound & Mic
- Volume keys
- Proximity sensor
- Jack
- Bluetooth
**Not Working:**
- Accelerometer
- GPS
Many thanks for the new version ## 2020.16.11
After flashing to a card and reparing the wrong GPT backup position, the system does boot with the fantastic animal logo Wink
For unlocking with "1234" a special keyboard does appear, but afterwards I could not get any keyboard and therefore it was not possible to enter the password for WiFi etc.
Any tricks to solve that problem?
Question
Could anyone answer some questions I have regarding the openSUSE images?
  1. What is the difference between the pinephone.aarch64.raw.xz image and the pinephone.aarch64-2020.11.16-Build9.3.raw.xz one?
  2. Considering they aren't disc image files, do I have to modify them in some way so I can flash them?
  3. Why is the nightly image page no longer available?
Appreciate any info you can share.
Do anyone know if Anbox can be installed/works on openSUSE ?
With latest image "openSUSE-Tumbleweed-ARM-PHOSH-pinephone.aarch64.raw" from 2020-11-18 the problem that no keyboard pops up when input is required still persists.
Am I the only idiot trying to get OpenSuse running?
Quote:Am I the only idiot trying to get OpenSuse running?
So it is... Angel
So it is... Angel
No I have run opensuse. Didn't see same problems although I used openSUSE-Tumbleweed-ARM-PHOSH-pinephone.aarch64-2020.10.25-Build5.1.raw
I am also burning these images using DD, win32diskimager, and etcher depending on where I am at and what OS I am booted into. And if I feel like seeing a 'kids' ui.
No issues with input on my side.
  asterisk or FreePBX on pinephone? vanja 0 1,042 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 26,094 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,399 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 250,965 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 237,130 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,541 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,941 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,528 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,398 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,853 07-26-2024, 10:35 PM
