Post Your Desktop
#21
(10-14-2020, 12:50 PM)Upokupo Wrote:
(10-14-2020, 06:41 AM)bastafari Wrote:
(10-13-2020, 07:50 PM)Upokupo Wrote: My Manjaro Gnome desktop setup.
Nice rounded corners, is that a gnome thing or just the theme?
Sent from my OnePlus 7 Pro using Tapatalk
It's the Orchis theme by Vinceliuice. I enjoy his various themes. He does both gtk and kde themes.
How do you add that app launcher on the bottom?
I tried installing several of these themes and made sure to make it change the default layout but it doesn't show it. I can't find any such widget either.
That might be latte dock
#23
It's the dash-to-dock gnome extension.  In the extension settings you can move it to the left hand side like I did. The default setting is on the right hand side. Also! There is a floating dash-to-dock that makes it look like the top panel. I just recently installed that one as i like the look and feel of the floating panels/dock.
If you need any more help, just ask. Smile
#24
Thanks! I tried installing/looking it up on the manjaro widgets/plasma style/theme menu but couldn't find it. How do you set it up in manjaro?
#25
(10-29-2020, 06:53 PM)pineitup Wrote: If you need any more help, just ask. Smile
You need to install the gnome desktop environment. You're using the KDE plasma desktop environment. If you want to achieve something similar in KDE you can install latte dock and configure that. I haven't been on Manjaro KDE for a while and not sure of the status of latte dock. But the beauty of the latte dock is you can add plasma widgets to the dock including menu launchers and achieve something similar. You just need to drag the widget onto the dock.
#26
My EndeavourOs  i3 + Polybar .
[Image: e5182fd8fe44acbf08e1ec18bb37ef61705d61fb.jpeg][Image: 2553be7051c2de26ef075e38dc92006290aa671d.png]
#27
If the conky looks familiar , its because I got it from this thread.  Rest is in the neofetch
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 2 6,605 08-10-2025, 10:35 PM
Last Post: Pattienner
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 5,291 06-01-2023, 10:58 AM
  Desktop gui gone tlgalenson 1 2,363 12-27-2021, 07:35 PM
Last Post: ryo
  Cube Desktop on Pinebook Pro decisivedove 1 3,921 04-15-2021, 01:12 PM
Last Post: wpeckham
  Pinebook Pro won't post after hard reset i6Shot 15 21,954 09-28-2020, 12:45 PM
Last Post: i6Shot
  manjaro pacman desktop? jcarty 2 5,217 09-13-2020, 04:47 PM
Last Post: carlosqueso
  Installing Ubuntu Unity Desktop instead of Ubuntu Mate/Kubuntu andybleaden@gmail.com 7 12,061 01-27-2020, 02:47 PM
Last Post: andybleaden@gmail.com
  how to attach video file to forum post richfm 2 5,980 11-27-2019, 12:10 PM
Last Post: richfm
  [Temp Post] We have the trackapad/ keyboard firmware Luke 23 39,044 11-22-2019, 09:43 AM
Last Post: Luke
  Run Linux desktop as an Android application Vasant 7 13,029 11-13-2019, 02:14 AM
Last Post: Wizzard
