Video Tut: Set Up SSH Access To Your Own Pinephone .onion (security enhancement)
Lightbulb
Many Pinephone users have ssh access open. Result being their Pinephone's ssh server shows up/is by default accessible on the open internet. This can be dangerous (especially given many undoubtedly use weak number passwords (ie: guessable numbers doubling for screen unlock pin)),
So I thought fellow Pinephone users may find this video helpful.
A quick (5min), easy video walkthrough/guide. A simple to implement security enhancement (using Mobian Pinephone as example in the video but will work on any Linux).
Make your Pinephone ssh server only accessible as a Tor .onion address (Blocking access/portscans/shodan for users on standard internet).
https://youtu.be/syKZNMVxTM4
After following the video, edit  /etc/ssh/sshd_config and uncomment/edit the line to match:
ListenAddress 127.0.0.1
Optionally (in case anything in ssh config goes wrong) block using iptables issue the following afterwards:
sudo iptables -A INPUT -p tcp -s 127.0.0.1 --dport 22 -j ACCEPT sudo iptables -A INPUT -p tcp --dport 22 -j DROP
The above iptables commands block ssh access to your Pinephone from all parties outside your Pinephone localhost address itself (used by tor locally). This means it won't show up when portscanned, won't show up on shodan, and cannot be brute forced without having your personal .onion address. Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
  Mobian image for the PinePhone Korfou 2 2,113 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,821 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,341 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,112 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,565 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,385 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,656 01-02-2025, 12:47 PM
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 10,203 01-08-2024, 02:50 PM
Last Post: ERPlegend
  PinePhone won't boot after software update jb2000 2 5,155 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 7,146 03-01-2023, 04:45 PM
