Automatically run after power recovery
Dears, can you tell me which GPIOs are used to control volume up volume down as when power gets back ROCK64 boots into recovery and I can not navigate through it.
[quote pid='46594' dateline='1558909836']
where can find the numbers of components to try this modification, the Rock64pro dont have component number in the board,
do you have a board outline with number components?
Can you help me?
[Image: attachment.php?aid=1336]
[/quote]
(07-27-2019, 08:51 PM)TheWiley Wrote: I played a bit with this today and found that the auto-power-on seems to work less than 1/3rd of the time for me. When it does work, I do see the ethernet NIC lights come on immediately and the board starts responding to ping 30-60 seconds later. When it doesn't work, I get no NIC lights. I think that means I have a hardware problem?
If it makes a difference, I'm running with the 12v/5A PSU.
It also seems to matter how long the power is off - I haven't checked systematically, but auto-start seems to be more reliable if the board is unplugged for more than a minute or so. Does that make sense?
Did you manage to find a solution? I have the same issue, only my board never auto boots after re-powering, not matter for how much time I unplug it. The green LED next to the power jack lights up, but the ethernet NIC lights don't. The only way to start it is by pushing the power button. I'm also using the 12V 5A PSU from the Pine store.
I have this problem with rockpro64 and PSU 12v5a from pinestore. Do you have any solutions ?
I can confirm the same bad behaviour: after power loss or even if the power is disconnected manually, the rockpro64 does not boot anymore until the power button is pressed or the board gets cool in a few hours  Angry
  RockPro64 automatically run after power recovery - my solution g2t 1 1,839 05-28-2026, 05:29 PM
  Rock Pro 64 Won't power on matthewmkr 9 9,050 04-29-2025, 12:57 PM
Last Post: matthewmkr
  power button not working Vista8720 0 3,486 05-07-2024, 11:26 PM
Last Post: Vista8720
  enble boot after power loss/restore dkebler 18 30,889 12-04-2023, 12:14 PM
Last Post: ok38
  PCIE interface power on too late Slark Xiao 0 3,028 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 6,064 11-17-2022, 06:13 PM
Last Post: acj_
  After Power Loss feature working bdherouville 2 6,113 08-22-2022, 03:52 AM
Last Post: bdherouville
  PWM fan control low power Connar 0 3,021 12-12-2021, 05:58 AM
Last Post: Connar
  ROCKPro64 sometimes doesn't Power On Pete Tandy 2 6,729 08-24-2021, 05:50 AM
Last Post: Pete Tandy
  Power Supply availability S265 2 7,110 06-07-2021, 09:20 PM
Last Post: S265
