Pinebook Pro Sleep/Resume bug: The (Kinda sorta) Good, The Bad, and the (Very) Ugly.
So it sounds like without NVMe, suspend should work if one takes some extra steps - but with NVMe, suspend is not currently possible. Just checking in case it's specific to certain models of NVMe - is there anyone who has suspend working and an NVMe drive? If so - what NVMe are you using?
@xmixahlx
you need:
5.7+ manjaro kernel
bsp-based uboot -- still recommend mrfixit 2.0
systemd configuration for mem suspend and disable hibernate (and disable power button...)
Suspend first worked with a 5.6 tsys kernel (not the very 1st,,2nd I think), with recent update, still works,,~7%/d
Since lid switch is flakey, better to disable that (systemsettings5), or fix
I enter/leave s3 with pwr button, in systemsettings5 set for log out dialog, so needs 2 extra keystokes
(and yes, explicit statement in sleep.conf,, SuspendState=mem)
I do wish I knew how the resume works, for me, pwr button or plugging in charger
Some distros sleep, but never wake (so unclear how well they actually are doing, as well as useless)
And,, BTW I don't have nvme installed, just for this reason
I'm now actually pretty sure this is the mis-positioned magnet issue.
Won't know for sure until my wife's available to help me attempt the fix next weekend. I'm partially blind / fine and gross motor impaired and the instructions ("There is no easy way to do this!" etc.) intimidate the heck out of me.
I'll mark it resolved if that does indeed fix it. I'm not using an NVME SSD. Stock emmc.
  Boot Order in Pinebook Pro food 12 17,681 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,833 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,924 08-09-2025, 06:53 AM
Last Post: Sb2024
  What's a good image to use now? [tutorial help as well] frank_philip 40 30,613 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,236 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,537 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,063 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 16,986 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,024 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,198 12-11-2023, 03:47 AM
Last Post: calinb
