Pinephone dock with Pinebook Pro?
Has anyone attempted (or had success) using the usb-c dock from the Pinephone convergence package with their Pinebook Pro?
I've been able to use it as a usb hub, but I have not gotten the HDMI out to work (I haven't had a chance to try the ethernet jack yet, that's on my to-do list).
I know there have been issues with PMOS and the HDMI on the dock, but I don't know if the the pbp would have the same issues (I'm running the out-of-the-box Manjaro on it).
(09-20-2020, 06:32 PM)karlnicholas Wrote: Has anyone attempted (or had success) using the usb-c dock from the Pinephone convergence package with their Pinebook Pro?
Yes, but I had to install the linux-pinebookpro kernel, and it seems to work only when I boot up the system with the dock and display attached. Ethernet is also working.
Update:
Attaching the dock when the PBP is running is also possible, however it seems to work only in one orientation. So if your dock is not working, try rotating the connector 180 degrees.
Update:
Good to know, I'll have to check that out!
Update: It does indeed work, and just as you said, the HDMI out on the dock only works in one direction (happens to be upside down for me).
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,518 10-05-2026, 12:42 PM
  pinephone keyboard oliveira11670 1 2,605 05-20-2026, 09:19 AM
Last Post: zetabeta
  Replacement battery for PineBook Pro DrYak 5 9,361 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,103 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 5,720 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,901 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 4,955 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 3,902 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 3,908 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 237,983 09-13-2023, 03:43 AM
Last Post: k3dAR
