PineTab as SketchPad
Hey folks,
im trying to use the pinetab as a sketchpad.
I'm running arch linux.
Gimp and krita both work, but there is some lag between touch and the resulting line..
Now i wonder how to decrease the lag. Would a realtime (fully preemptible) kernel help?
I have built patched kernels myself in the past but am unsure how to build one for the PineTab.
does anyone have any ideas on this?
Maybe alternative approaches i could try?
(09-19-2020, 03:55 PM)K3nn3th Wrote: Hey folks,
Depending on the window manager you are running, you can try polling the display for touch updates (more energy use but in theory faster than waiting for a interrupt signal). [1]
Arch has some methods to increase polling rate [2]. Again, be aware this will tax the CPU more and energy consumption will go up. If the touch events are done over the same communication as the display updates then it gets more messy if the channel is already saturated.
[1] https://unix.stackexchange.com/a/25712
[2] https://wiki.archlinux.org/index.php/Mouse_polling_rate
  New Pinetab- error when attempting to install updates authorjaw 1 1,480 02-26-2026, 01:21 AM
Last Post: Raik
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 2,316 03-23-2025, 05:25 AM
Last Post: bartgrefte
  PineTab 2 login screen rotation fix chzbacon 11 18,949 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 8,248 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 5,323 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 7,899 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 15,060 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 49,350 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 2,740 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 249,598 04-26-2022, 11:58 AM
Last Post: thomzane
Users browsing this thread:
