VS Code running on PineTab
... using vs code server and the browser.
> wget https://github.com/cdr/code-server/relea...m64.tar.gz
> tar -zxvf code-server-3.5.0-linux-arm64.tar.gz
> cd code-server-3.5.0-linux-arm64/
> ./code-server --auth none
browse to 127.0.0.1:8080
(09-12-2020, 01:29 PM)brentashley Wrote: ... using vs code server and the browser.
Do i need to do some steps before this? Because i am getting failures.
(09-12-2020, 02:48 PM)m.alizade7 Wrote: Do i need to do some steps before this? Because i am getting failures.
What failures are you getting? Just worked for me, not sure if other changes I had made prepared it to work.
if you cut and pasted, you may have got the abbreviated link that the forum software created
the full link is as below (but without the space)
https://  github.com/cdr/code-server/releases/download/v3.5.0/code-server-3.5.0-linux-arm64.tar.gz
thanks for the hint! I've never heard about this code-server, but it looks pretty interesting for my plans for "remote development". How's the performance? Have you compared this setup to running the code-server server part on a remote machine, and accessing it via a browser?
(09-13-2020, 02:31 PM)Lex-2008 Wrote: thanks for the hint! I've never heard about this code-server, but it looks pretty interesting for my plans for "remote development". How's the performance? Have you compared this setup to running the code-server server part on a remote machine, and accessing it via a browser?
I find it extremely responsive, even with plugins and doing full debugging.
It's really great to use in hard to reach places.  I have even used it when using the Google Cloud Console vm in GCP.
 I am getting No Authentication & Not serving HTTPS.
That sounds like what the server tells you when it is working properly (we told it to use no authentication did not request HTTPS).  Keep that terminal window open and change to the browser, then go to 127.0.0.1:8080 and that should connect the browser to the VSCode server and bring up the editor interface.
Sorry for a late reply, but I did it today and it worked!
  Pinetab2s running DanctNIX just got Bluetooth!! biketool 0 352 11-02-2025, 04:45 AM
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 1,260 03-23-2025, 05:25 AM
Last Post: bartgrefte
  PineTab 2 login screen rotation fix chzbacon 11 12,872 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 6,084 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 3,675 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 5,588 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 10,920 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 41,894 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 1,943 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 211,117 04-26-2022, 11:58 AM
Last Post: thomzane
