sudo / lock screen password keeps resetting to default
This is the second time I have installed mobian on the eMMc of my Pinephone UBPorts Edition.
The first time I changed the password from the default "1234" using the terminal emulator with the
command "sudo passwd" and it worked.
However, after making some annoying changes I couldnt revert, I decided to reinstall everything and now,
when I try to change the password in the terminal emulator using the same command "sudo passwd", it says:
passwd: password updated successfully
But, when I lock the screen and then attempt to unlock it with the new password. It doesnt work.
When I try with the default "1234" password it works like if I had never changed it "successfully".
Not sure what is happening or what Im doing wrong, maybe Im just tired. Any ideas?
Reboot.
(09-03-2020, 08:59 AM)jed Wrote: Reboot.
Yeah that doesnt fix anything for me. When I type the password I "successfully" set in the terminal it reads "Checking..." and then fails to unlock.
I put the original passcode "1234" and the screen unlocks.
how about sudo passwd mobian, or just passwd (think you need the sudo to avoid moans about numeric only password?)
(09-03-2020, 12:37 PM)dukla2000 Wrote: how about sudo passwd mobian, or just passwd (think you need the sudo to avoid moans about numeric only password?)
Yep.
Not anymore Wink
Yes!! It worked!
sudo passwd mobian
Thank you, this was annoying me so much lol.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 573 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 8,449 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,251 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,590 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,730 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 9,198 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,096 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,257 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 16,261 06-22-2023, 11:20 AM
Last Post: Melechtna
  4G data on default startup / boot dcinoz 1 2,721 04-29-2023, 11:24 PM
Last Post: dcinoz
