Pinebook Pro Won't Accept Login
Now's your opportunity if you have ideas about different operating systems. I can tell you that Armbian is pretty reliable. But you don't get things like battery status in a default installation. Debian works well too. Of course there's a plethora of operating systems to choose from now.
(09-01-2020, 11:45 PM)KC9UDX Wrote: Now's your opportunity if you have ideas about different operating systems.  I can tell you that Armbian is pretty reliable.  But you don't get things like battery status in a default installation.  Debian works well too.  Of course there's a plethora of operating systems to choose from now.
Excellent. Thank you very much. I really appreciate the assistance and insights.
Good thing I was looking for something I could tinker with and learn from. There's lots of learning going on before I even get it working.
Best,
I have the same problem, after setting up and configuring user name and password then rebooted to to start tinkering the login screen would not accept the user name and password. How do I rectify this? At this point I cannot use the PBP..
(09-02-2020, 08:38 AM)sccarey59@gmail.com Wrote: I have the same problem, after setting up and configuring user name and password then rebooted to to start tinkering the login screen would not accept the user name and password.  How do I rectify this? At this point I cannot use the PBP..
I'm still a newbie, but from what I can tell, the only fix is to boot from the SD card and try to set it up again. Without being able to login, I can't do anything.
Of course, there's no promise that will work. I'll have to figure it out and let everyone know whether or not it's a success. I might go through all that and get exactly the same thing, in which case I currently have a paperweight running Linux.
Best,
With the number of people using Manjaro on these machines now, these kind of problems are very likely to be fixed soon.
Otherwise, consider that Debian was the default OS prior to Manjaro.  You could still use Debian.  And it's not like that's been stagnating since Manjaro came along.
Here's what I did when I ran into problems with the OS on my eMMC: I gathered up all the stray MicroSD cards round the house and installed Chrome OS, Armbian, Manjaro, Android, and a few others on them.  I had to turn off the eMMC, but it gave me a chance to play with the PBP with different operating systems before I sussed the eMMC troubles I created.
(09-02-2020, 03:24 PM)KC9UDX Wrote: With the number of people using Manjaro on these machines now, these kind of problems are very likely to be fixed soon.
That's a great idea. Thank you. If I'm interested in learning, this is a great way to go.
Thank you again.
Best,
Graham
Err, it is quite fast,, editing shadow, in your case emmc/etc/shadow
(check where you are, so as not to edit SD shadow,, pwd ,, print working directory (should start /media/....)
Just yesterday, I had to edit shadow,, damn password nazi's,,
here, have a blank password, how do you like them apples?
Oh, so now you'll take the password of MY CHOICE without complaint?. Well, good
Use often up-arrow and tab(completion) to reduce typing and avoid errors
mount|grep mmc (are there 2 blks? mmcblk1 & mmcblk2? If so, emmc mounted)
mount|grep media (if a SD boot, emmc likely mounted on /media, you want p2, not boot)
So, cd to emmc/etc, become root, copy shadow for backup, remove password hash between 1st 2 colons ":"
so it ends up (yes, the password hash is rather long, 50-60 chars, this is normal)
root::<other stuff>
Since most dm's don't like a root logon, do for $USER as well ($USER= your login name, bottom of shadow)
  Pinebook Pro for sale rfm83 0 322 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,805 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,832 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,124 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,694 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,059 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 23,323 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,670 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,559 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,180 01-19-2025, 04:38 PM
Last Post: ColoBill
