Which Linux builds enable hardware accelaration?
Question
Hi everyone,
Just made an account here to ask this question.
I've been looking into making a Plex server on a SBC for a long-time now and I recently found the RockPro64. It seems to be the perfect entry level Plex server, but I've also been reading about a lack of dev support for this device compared to the R-Pi. I am somewhat proficient in Windows (read as "I need a GUI" or "I can double click .exe shortcuts and start wizards with the best of them!"), but I really don't know what I'm doing when it comes to Linux. I haven't used Linux in years and even then I was clueless. In terms of choices for OS, there are several (https://wiki.pine64.org/index.php/ROCKPr...ng_Started), but from what I read in a year old thread, I'm going to have to use Armbian (https://forum.armbian.com/topic/9310-rk3...-renegade/) to enable hardware acceleration.
That can't be right, can it?
My long-term goal is to have 3 RockPros that can stream Plex. I want to continue using GDrive for file hosting, and I plan on using rClone to mount GDrive to an SSD, mount the SSD on a RockPro64, install Plex, point it to the GDrive directory. Repeat 2 more times and give myself and 2 others a nice Christmas present with personalized streaming and an easy way of refreshing content across multiple different home networks (read 30 Mbps down, shitty upload speed).
Maybe I'll make a VPN down the line and use it to remotely access my streaming setup. Maybe.
Thoughts?
you can use the linux hwaccel patch in pbp-tools with pbp-install-linux script to build an hwaccel kernel for rockpro64, too.
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,214 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No Hardware Interrupts for GPIO pantera 2 8,095 05-08-2021, 10:16 AM
Last Post: Badger
  Linux reboot command dont' restart davide.duca 2 7,276 03-11-2020, 03:15 PM
Last Post: dukla2000
  Thoughts on Linux OS vs Just Enough Linux Media Boxes buzzmarshall 1 4,564 03-25-2019, 10:29 PM
Last Post: odhinnhrafn
  Hardware issue overheating while booting and fail to boot DIDquest 13 27,335 03-23-2019, 02:50 AM
Last Post: nJoy.
  7″ LCD Pine64 touch screen + RockPro64 + Linux Impact 0 4,469 02-07-2019, 04:03 AM
Last Post: Impact
  Camera support for linux image in rockpro64 rahulsharma 1 4,973 01-26-2019, 09:48 AM
Last Post: anykey
  Nvidia Linux-32bit ARM drivers on Rock64 Pro gbajson 6 14,595 07-12-2018, 08:02 AM
Last Post: joe2gaan
