Linux Images (ROCK64)
Is Ubuntu 20.04 supported on the Rock64?
(01-14-2020, 12:23 PM)dpgraham Wrote: Ahh That makes sense, thanks evilbunny!
I guess that's the downside of using an auto-installer, it's a black box Smile
Very cool, was not familiar with the use of zram.
Could anyone point me to a wiki that possible talks about the advantages of four 250M sized zram partitions versus one 1G zram partition? just curious.
edit: Please and thank you!
https://en.wikipedia.org/wiki/Zram
I think having all the RAM as ZRAM is not an advantage. A part of the RAM could be.
With 1 GB of RAM it could be little, so if you compress part of that RAM, you will gain memory space in exchange for the cost of the CPU.
If you have some RAM as ZRAM, you could put this ZRAM as swap and most recent used memory will be in RAM and the other in ZRAM.
If you have all RAM as ZRAM, the CPU cost will be higher and more delay in running processes.
In addition you can also put a partition in ZRAM, such as /tmp and avoid many writes to disk (obviously using RAM).
(05-05-2020, 12:22 PM)scalextrix Wrote: Is Ubuntu 20.04 supported on the Rock64?
Official support, I don't know. Arm64 support, yes.
Official armbian support (https://www.armbian.com/rock64), no. It works well? Yes.
I use armbian 20.04 on rock64, the repositories are fine and it works fine overall.
Sad
just flashed microSD with bionic Mate and booted on PBP. At login prompt, I put "rock64" as password, I am then prompted to change the password at first login. Once I change it, I receive "invalid password, please try again".
How do I login to the desktop?
I've tried many rock64 images to try to get my wifi dongle to work. from debian, armbian, and manjaro. It only works on android 7.1. Any recommendations? I would prefer it to work on armbian because I prefer this OS over the others. If this helps, the chipset that's in the USB wifi dongle is RTL8188. Thank you!
(01-05-2021, 10:43 AM)DuckyBoi Wrote: I've tried many rock64 images to try to get my wifi dongle to work. from debian, armbian, and manjaro. It only works on android 7.1. Any recommendations? I would prefer it to work on armbian because I prefer this OS over the others. If this helps, the chipset that's in the USB wifi dongle is RTL8188. Thank you!
Check if you have the correct module loaded, check these webs:
https://wiki.debian.org/es/WiFi
https://wiki.debian.org/rtl818x
https://wiki.debian.org/rtl819x
Also if the module does not exists in that kernel version, you could try installing it, check on Github some repository:
https://github.com/search?q=rtl8188
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,620 Yesterday, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,694 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,086 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,975 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,864 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,197 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,379 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,367 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,465 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,304 09-01-2024, 06:05 AM
