[split] U-Boot with NVMe support, keyboard & display working
This was just posted by @sigmaris on IRC.
https://lists.denx.de/pipermail/u-boot/2...07894.html
And the patches (quite fresh):
http://people.hupstream.com/~rtp/pbp/20200706/patches/
Actually, I'd put the builtin USB keyboard at a higher priority than the eDP.
With USB keyboard support, (builtin and or external), we can setup a sequence of events at boot:
  • Pause & blink LED, (which one?), for a short time, (5 seconds?). Perhaps power LED, alternating red & green.
  • During this time, accept keyboard input
  • Select boot device of:
    1. USB
    2. MicroSD card
    3. NVMe
    4. eMMC
With this, we can leave an SD card installed, and over-ride booting to it.
Or even allow re-arranging the default boot order to be fastest first, since we can select something else if needed.
  1. NVMe
  2. eMMC
  3. MicroSD card
  4. USB
Arwen Evenstar
Princess of Rivendale
I tried to build uboot with patches from @pcm720 + patches from Arnaud to enable eDP support in uboot.
I failed miserably. All the patches apply correctly (on top of 2020.07) and uboot builds ok but resulting SPI image does not boot. Probably something missing in config.
Unfortunately i'm away from home and don't have my serial cable with me Sad
OK, so I finally was able to build working (sort of) uboot with nvme boot, display and keyboard thanks to Arnaud and @samueldr work.
It boots my 5.8-rc5 but inconsistently. In 15 tries I have 5 failed boots.
If someone is brave enough to test it - I can share SPI image or images for SD/eMMC.
(07-15-2020, 12:59 PM)as400 Wrote: OK, so I finally was able to build working (sort of) uboot with nvme boot, display and keyboard thanks to Arnaud and @samueldr work.
I'd be happy to try the SPIFLASH build--I can always back it off and rewrite the working one.  I do have serial output enabled so I can probably help debug.  if you are still without your serial cable.   I would be using a standard Manjaro 5.7 kernel.  I think we are using the same brand/model of NVME  SBXe  except mine is only a 480G.
@as400, Is there really any reason why it can't be on the eMMC for testing?
Even if testing, (and further modifications), takes months, putting on the eMMC is both easier to recover, (via the disable switch). And might actually be faster. Whence it's working with all the features we want, then put it in the SPI.
As for the display and keyboard support, wonderful.
Now can I get greedy and ask for a simple menu to select the boot device?
Then a timeout to boot the default order, (whatever that ends up being).
Arwen Evenstar
EDIT 16.07.2020 - included images with menu
EDIT 29.07.2020 - new version posted on page 3
So if someone wants to test here are the images (there is NVME boot included in all of them):
REMOVED
Maybe we should move this discussion to another thread so we don't hijack this one ? @Arwen  ?
@as400, Split done.
Notify other user, @belfastraven
On the main subject, I'll try and see if I have time over the next week to install and test.
Arwen Evenstar
Great - testing needed.
Especially those random kernel lockups are annoying.
@as400, oh, in my rush to learn forum post splitting, I forgot to say;
Thank you!
Arwen Evenstar
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 736 04-04-2026, 08:00 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 976 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,517 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 26,898 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 16,813 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Keyboard issue j0rs 3 4,652 01-20-2025, 07:03 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,555 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,901 12-25-2024, 10:12 PM
Last Post: jessipinkman
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,192 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 3,529 11-25-2024, 03:42 PM
Users browsing this thread: 9 Guest(s)
