ROCKPro64 has Lithium Battery Port yes or no?
In https://www.pine64.org/rockpro64/ it is indicated that ROCKPro64 has Lithium Battery Port in the manner of Pine64+ and Pine64-LTS, and the photo seems to show a battery connector. But in https://wiki.pine64.org/index.php?title=ROCK64 there is no mention of a lithium battery port and that clearly looked like the battery connector, it is labeled "SPDIF header" and the other possible port candidates are labeled as "PWM controlled fan header", "RTC battery backup header" and "DC out for SATA disk cable".
(06-24-2020, 04:00 AM)anfast Wrote: In https://www.pine64.org/rockpro64/ it is indicated that ROCKPro64 has Lithium Battery Port in the manner of Pine64+ and Pine64-LTS, and the photo seems to show a battery connector. But in https://wiki.pine64.org/index.php?title=ROCK64 there is no mention of a lithium battery port and that clearly looked like the battery connector, it is labeled "SPDIF header" and the other possible port candidates are labeled as "PWM controlled fan header", "RTC battery backup header" and "DC out for SATA disk cable".
Yes.
See label 6 in the RockPro64 wiki.
The battery connector is intended for backing up the RTC, not for powering the whole board. If you wanted to power the whole board from a large lithium battery, you would need to have some way of the battery supplying 12V through the barrel jack, i.e. a separate charging & power supply circuit.
If so, the information on the website ( https://www.pine64.org/rockpro64/ ) is wrong (it incorrectly indicates that it has a Lithium Battery Port that it does not have) and should be corrected.
Thank you very much for answering my question.
  where to get debian 12 image for rockpro64? heocb 1 3,437 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 2,949 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,382 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 3,864 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,077 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,066 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 11,866 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,403 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 5,511 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 7,094 03-19-2023, 06:22 AM
Last Post: runyor
