Pinephone UBport Edition no OS preinstalled
Hi, I just received the Ubuntu Edition pinophone, I removed the film on the battery and turned it on.
The phone is in "boot loop" showing the pinecone for a few seconds, then a black screen with the LEDs changing from red to white to blue and then the pinecone. Endlessly.
I think I need help. Shouldn't the Ubuntu touch OS be pre-installed?
Sad
Update: now on power-up it shows the pine cone only once, then black screen with steady red LED.
Yes, mine started first time.
Check the FAQ https://forum.pine64.org/showthread.php?tid=10130
(06-08-2020, 10:22 AM)malditobastardo Wrote: Check the FAQ https://forum.pine64.org/showthread.php?tid=10130
FAQ don't help. I've tryed shutdown and restart many times, but the result is the same.
Restart loop 3/4 times and then black screen and red led.
Have you tried charging the phone? Maybe the battery is nearly empty. I'd do that - completely remove the battery (hard power-off Smile), put it back in, put it on a charger overnight and try again.
Oh, btw, did you see this thread?
I've tryed the "telnet" thing, but doesn't work:
telnet 172.16.42.1
Trying 172.16.42.1...
Connected to 172.16.42.1.
Escape character is '^]'.
Welcome to Rescue SD Shell!
/ # umount /dev/mmcblk2p10; e2fsck -fy /dev/mmcblk2p10 && sync
umount: can't unmount /dev/mmcblk2p10: Invalid argument
e2fsck 1.46-WIP (20-Mar-2020)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/mmcblk2p10
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
   e2fsck -b 8193 <device>
or
   e2fsck -b 32768 <device>
/ # sync && reboot -f
After the reboot is the same, pine 64 and after black screen with red led.
Did you defragment the EMMC like it said?
or
or
You followed the other steps before doing that? You have to be in jumpdrive mode (Recovery mode basically)
(06-08-2020, 08:52 PM)Aberts10 Wrote: You followed the other steps before doing that? You have to be in jumpdrive mode (Recovery mode basically)
I've followed every step. All was ok, I see the orange robot and i read the 'Welcome to Rescue SD Shell!'.
The first error is when I try to unmount /dev/mmcblk2p10.
  ADB support on Pinephone Sumwun 3 5,145 09-27-2023, 04:04 PM
Last Post: Sumwun
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 16,618 06-26-2023, 07:50 AM
Last Post: gregb49
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 3,042 05-12-2023, 05:06 AM
Last Post: c3l@
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 8,190 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 11,009 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  Images won't boot past pinephone logo remington_luger 9 18,941 08-22-2021, 09:56 AM
Last Post: remington_luger
  GhostCloud workaround for PinePhone mark1250 1 6,912 08-12-2021, 02:53 AM
Last Post: Uturn
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 27,549 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 13,159 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  Horrible energy consume on Pinephone/UB-Touch firefox-58 9 18,213 10-15-2020, 12:28 PM
Last Post: plainenough
