Built-in Webcam Not Working
I received my PBP today, and just trying out all the features, but for some reason I can't get the built-in webcam to work.
I've tried Kamoso and Cheese - cheese outputs this "cheese-application.vala:214: Error during camera setup: No device found"
Under the /dev/ there is /dev/video0, /dev/video1, /dev/video2. Using that, I've tried smplayer /dev/video0 as well as video1 and video2, but nothing shows.
I've also checked that the webcam is enabled (double flash from [Pine]+[F12]).
Can someone help me diagnose this please?
check if your user is added to the video group
dmesg|grep video
if not detected, toggle the privacy hardware disable and reboot
dmesg again
the camera works, but is not great
On my system, the camera is /dev/video3. video0, video1, video2, and video4 are all different handles on the video processing unit, as I understand it, and won't respond correctly when opened under the assumption that they're cameras.
Does yours not have a /dev/video3?
I also received my PBP today too! Have you tried enabling it via the privacy switch?
https://wiki.pine64.org/index.php/Pinebo...y_Switches
(05-28-2020, 07:49 PM)xmixahlx Wrote: check if your user is added to the video group
dmesg|grep video
dmesg again
Yes, my user is added to the video group.
Here is my dmesg output (doesn't change if the privacy switch is enabled or disabled):
$ dmesg|grep video
[    0.000000] Kernel command line: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
[    0.276266] videodev: Linux video capture interface: v2.00
[    8.459274] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[    8.472188] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    8.472803] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[    8.472906] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
As you can see - only video 0, 1 and 2 are detected
exact same problem here...
Also having the exact same issue with a PBP from the latest batch .
what happens if you use a different OS from sdcard?
dmesg|grep video
dmesg again
$ dmesg|grep video
[opvolger@pine64 ~]$ dmesg|grep video
[    0.286198] videodev: Linux video capture interface: v2.00
[    6.521834] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[    6.527476] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    6.530597] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[    6.530769] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[    8.693178] uvcvideo: Found UVC 1.00 device USB Camera (0c45:6321)
[    8.729161] uvcvideo 2-1.2:1.0: Entity type for entity Extension 4 was not initialized!
[    8.729175] uvcvideo 2-1.2:1.0: Entity type for entity Processing 3 was not initialized!
[    8.729182] uvcvideo 2-1.2:1.0: Entity type for entity Camera 1 was not initialized!
[    8.730958] usbcore: registered new interface driver uvcvideo
output of a working webcam. (is the same).
I received my laptop this week. Only had problems with WIFI (so was turned off, privacy switch). My webcam works.
https://wiki.pine64.org/index.php/Pinebo...y_Switches <- switches. i had to reboot.
The future is here! ARM laptops!
(06-07-2020, 01:55 AM)xmixahlx Wrote: what happens if you use a different OS from sdcard?
I tried Manjaro KDE, Debian and Android images, camera did not work in any of those.
I also tried switching the camera off with SUPER + F12, rebooting, switching it back on and rebooting again. Still no luck.
My dmesg | grep video output:
[    0.316806] videodev: Linux video capture interface: v2.00
[    6.883165] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    6.885306] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1
[    6.888777] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video0
[    6.895759] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
If I try to run smplayer /dev/video1 I'm getting this error:
/usr/bin/mpv --no-config --no-quiet --terminal --no-msg-color --input-ipc-server=/tmp/smplayer-mpv-80f --msg-level=ffmpeg/demuxer=error --no-fs --hwdec=no --sub-auto=fuzzy --no-input-default-bindings --input-vo-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=77594644 --monitorpixelaspect=1 --osd-level=1 --osd-scale=1 --osd-bar-align-y=0.6 --sub-ass --embeddedfonts --sub-ass-line-spacing=0 --sub-scale=1 --sub-font=Arial --sub-color=#ffffffff --sub-shadow-color=#ff000000 --sub-border-color=#ff000000 --sub-border-size=0.75 --sub-shadow-offset=2.5 --sub-font-size=50 --sub-bold=no --sub-italic=no --sub-margin-y=8 --sub-margin-x=20 --sub-codepage=ISO-8859-1 --sub-pos=100 --volume=55 --cache=auto --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --screenshot-directory=/home/nick/Pictures/smplayer_screenshots --audio-pitch-correction=yes --volume-max=110 --term-playing-msg=MPV_VERSION=${=mpv-version:}
INFO_VIDEO_WIDTH=${=width}
INFO_VIDEO_HEIGHT=${=height}
INFO_VIDEO_ASPECT=${=video-params/aspect}
INFO_VIDEO_FPS=${=container-fps:${=fps}}
INFO_VIDEO_FORMAT=${=video-format}
INFO_VIDEO_CODEC=${=video-codec}
INFO_AUDIO_FORMAT=${=audio-codec-name}
INFO_AUDIO_CODEC=${=audio-codec}
INFO_AUDIO_RATE=${=audio-params/samplerate}
INFO_AUDIO_NCH=${=audio-params/channel-count}
INFO_LENGTH=${=duration:${=length}}
INFO_DEMUXER=${=current-demuxer:${=demuxer}}
INFO_SEEKABLE=${=seekable}
INFO_TITLES=${=disc-titles}
INFO_CHAPTERS=${=chapters}
INFO_TRACKS_COUNT=${=track-list/count}
METADATA_TITLE=${metadata/by-key/title:}
METADATA_ARTIST=${metadata/by-key/artist:}
METADATA_ALBUM=${metadata/by-key/album:}
METADATA_GENRE=${metadata/by-key/genre:}
METADATA_DATE=${metadata/by-key/date:}
METADATA_TRACK=${metadata/by-key/track:}
METADATA_COPYRIGHT=${metadata/by-key/copyright:}
INFO_MEDIA_TITLE=${=media-title:}
INFO_STREAM_PATH=${stream-path}
--audio-client-name=SMPlayer --term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} VB: ${=video-bitrate:0} AB: ${=audio-bitrate:0} /dev/video1
[ffmpeg/demuxer] video4linux2,v4l2: Not a video capture device.
[lavf] avformat_open_input() failed
Failed to recognize file format.
Exiting... (Errors when loading file)
I also tried Jitsi Meet and Google Hangouts, both in Firefox and Chromium, Kamoso and Cheese, nothing works.
Is there anything else I could do to check if the camera hardware works?
dmesg|grep video
dmesg again
$ dmesg|grep video
Actually, your output is different. Notice that you have these lines:
I'm not getting those, and it looks like fozzedout is not getting those lines either.
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 1,701 12-09-2022, 04:48 PM
Last Post: River
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 5,207 06-29-2022, 02:00 PM
Last Post: Chief
Sad Webcam not working in pinebook pro with Manjaro jcarball 2 6,134 04-28-2021, 03:23 PM
Last Post: jcarball
  [split] U-Boot with NVMe support, keyboard & display working as400 78 121,259 01-27-2021, 12:48 AM
Last Post: as400
  webcam photo solid gray stozi 0 2,323 01-05-2021, 05:35 PM
Last Post: stozi
  Booting to sdcard stopped working after emmc flash techiedog 3 6,101 12-31-2020, 06:30 PM
Last Post: Anarethos
  Needed basic Info on using Webcam on PBP User 17828 6 10,248 12-18-2020, 07:24 PM
Last Post: Arwen
  Wifi stopped working after updates pineitup 10 16,471 11-07-2020, 02:59 AM
  Working terminal emulator bookguy1 7 13,751 08-04-2020, 02:34 PM
Last Post: mfashby
  Suspend with NVME not working - Default Debian appdev46 5 12,851 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
