RockPro 64 MIPI Pinout
Is there a pinout for the RockPro 64 MIPI-CSI connector? Is this connector standardized across boards such as the Pi 3/4 and the Jetson Nano?
(05-20-2020, 08:42 AM)carbotaniuman Wrote: Is there a pinout for the RockPro 64 MIPI-CSI connector? Is this connector standardized across boards such as the Pi 3/4 and the Jetson Nano?
All the schematics are linked from the wiki, which also identifies all the RockPro64 connectors. No idea any pin compatibility - the physical connector is standard.
I see the schematic. Do you happen to know what voltage the SCL and SDA lines (on the MIPI CSI port) operate at?
(05-20-2020, 08:39 PM)carbotaniuman Wrote: I see the schematic. Do you happen to know what voltage the SCL and SDA lines (on the MIPI CSI port) operate at?
Nope sorry. And due to lockdown my RockPro and multimeter are in different locations.
  Can i use this Emmc for Rockpro 64 Supratec 2 5,217 12-20-2023, 09:12 AM
  red led blink on rockpro pine 64 Daniele14521 0 2,932 09-26-2022, 01:40 AM
Last Post: Daniele14521
  Is my rockpro dead? k0sm 6 10,927 12-30-2021, 07:32 PM
Last Post: Rocklobster
  Rockpro 64 with analog input jintao6889423 3 9,536 05-13-2021, 09:41 PM
  Camera sensor support on MIPI lines abhimanyu_gr 0 3,281 01-22-2021, 09:23 AM
Last Post: abhimanyu_gr
  Fedora 32 on ROCKPro 64. joeblues91 4 11,250 07-26-2020, 12:12 PM
Last Post: revoman
  RockPro 64 V2.1 Boot problem only DDR Version ... message nutilius 5 11,953 05-02-2020, 03:26 AM
Last Post: freeviv
  Calculate clock frequency for MIPI DPHY using different ref_clock value skumar 1 5,808 06-07-2019, 03:01 PM
Last Post: Nikolay_Po
  Non burst mode in MIPI DSI skumar 0 3,557 06-06-2019, 12:54 AM
Last Post: skumar
  Rockpro 64 maurora 1 4,638 05-24-2019, 09:50 AM
Last Post: Luke
