Remoting into Desktop Using PinePhone?
I am extremely interested in getting a PinePhone. I have this wild dream to use my PinePhone with external peripherals to remote into a desktop PC so I can use all of my juicy desktop applications on the go! One PinePhone to rule them all. Genius, right? I am imagining something like Teamviewer with the lowest latency possible.
DWService:
The best solution that I have in mind is DWService for PinePhone. How well does this work? Has anyone ever tried it or know where I could find a review?
[/url]
Apache Guacamole:
Similar to DWService, [url= https://guacamole.apache.org/]Apache Guacamole
seems promising since the client uses a web browser.
Parsec:
I am a curious new member in the Linux community, and I need a lesson on ARM distros. Can software intended for Raspbian run on PinePhone?
Hear me out... My thought process here is this: if Rasbian is an ARM port of Debian, and PinePhone is an ARM platform, then the software has a chance of working, right?
I am wondering if the remote control software Parsec will run on a Debian-based OS on PinePhone. Parsec officially supports the RaspberryPi and has a ".deb" file available for download. The setup guide for installing Parsec on the RaspberryPi is available here.
If anyone already knows of a working solution, I'm all ears!
Thank you for your time. Smile
(05-16-2020, 03:54 AM)SwankyBarbecue4 Wrote: ...
If debian has all the dependencies it could actually work. Try downloading and installing it with "dpkg -i name_of_deb_file".
I have seen there is a package "parsec47" on debian unstable. Not sure if it is what you are looking for.
Alternatively you could always run a VNC server on your desktop machine and install a VNC client on your phone (you would need something like dyndns and port forwarding though).
Thanks for replying.
After more thought, I am looking for a solution on Ubuntu Touch.
The VNC server is a great idea, but I couldn't port forward on my University's network. Are there any ways I could reliably get around this?
What about the web based applications, DWService (has a download for PinePhone) and Apache Guacamole, that I listed above? Could those work?
Thanks.
  Mobian image for the PinePhone Korfou 2 1,469 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,950 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,573 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,103 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 3,966 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,511 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,346 01-02-2025, 12:47 PM
Last Post: zetabeta
  desktop and lockscreen biketool 1 2,336 10-04-2024, 04:17 AM
Last Post: vusra
  unofficial kali linux for pinephone help needed pinesmell 5 9,626 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Has anyone got briar-desktop running on mobian? vusra 5 8,504 06-19-2023, 03:02 PM
Last Post: vusra
