i hate to bother you again but i'm trying to work on the power issue and i need to recompile the source with a couple of debugging options enabled. do you have the source hosted somewhere that i can do that? i couldn't find it on the gitlab page but i'm used to working with github so i may have missed it.
If you mean kernel sources you can clone this repo
https://gitlab.com/a-wai/linux-pinephone.git
(04-25-2020, 04:53 AM)Boern Wrote: Hmm, I tried it on Pureos and there the lockscreen is always shown in portrait mode.
And now I can't reproduce it in Debian either. I guess I just hit some edge case.
Probably, I couldn't reproduce it either.
thanx a lot rico. i used a script on a laptop once to put it to sleep, but when i tried it on the pinephone, i couldn't get it out without rebooting. i'll let you guys know if i get it working. i see where i was messing up now too, i had the img, not the source.
Monday is new release day Smile
As I hinted last week, this release changes the default scale factor to 1.8 (instead of 2). This means a higher effective resolution (400x800 vs. 360x720), so a few apps will display/work better with this release. Unless a huge number of people pushes back on this, I think this will be the default from now on, as I'm quite pleased with how things work this way. Comments and feedback are still welcome!
This required upgrading phosh and squeekboard by including not-released-yet code, so these are to be considered beta versions, but I didn't experience any regression during the last few days of testing, so I'm feeling confident this will work out for you too Smile
In case you don't like the 1.8 scale factor, feel free to delete /etc/phosh/phoc.ini or edit it to change the scale back to the previous version.
Regarding power management: thanks to smaeul's great work on crust, the modem can now wake the CPU up from deep sleep! The suspend mode is therefore deep sleep by default, but be aware that the "modem disconnect" issues are not solved yet, and might still require a reboot if things go wrong. Anyway, it's another step towards better power management, so I thought it was worth including in this release Smile
As last week, starting from a fresh image is recommended.
If you'd rather upgrade using apt, you'll have to run u-boot-install-sunxi64 and remove /etc/systemd/sleep.conf.d/suspend-s2idle.conf to benefit from the new power management features.
Enjoy!
Awesome!
This also adds squeekboard 1.9.1, which enabled modifier keys. So it should be possible to have a proper terminal layout now. I just have to find out how to do that.
I hope it also enabled tweaking the height of the keyboard so that we can fit more keys more comfortably in there. Especially with a scale factor of 1.8, as that makes the keys a little bit smaller.
Yeah, modifier keys work! See More useful terminal key layout for phosh's squeekboard
(04-27-2020, 11:23 AM)a-wai Wrote: ...
Another benefit of 1.8 over 2 is 5 icons in the favourites line Cool
Enjoy!
It is great, thank you to all still cooking this. Big Grin Big Grin Big Grin
WiFi hotspot sharing is pretty reliable now - I have tried to put instructions here in the wiki.
2 issues
a) I have struggled to get decent formatting of the "User Experience" section in the wiki - anyone who knows wiki formatting please feel free to have a go!
b) Even adding an dhcp-range 10.0.0.50,10.0.0.150 I cant get internet sharing to work via the USB port! I get an IP address assigned OK, I get 10.0.0.2 as the DNS but for whatever reason cannot access beyond the pinephone. Hints or suggestions from anyone who actually understands networking (I only read the 10 minute guide!) are welcome!
Is anyone having issues with the data activation since yesterday update? Only 3G shows up after reboot and in the settings the data are switched off by default. When I activate the data, it turns my data signal off.... It was fine before the update. A reboot didn't fix it either and I freshly installed the latest version. Thanks! And by the way, you guys are doing an amazing job and many thanks for it!!!!
(04-28-2020, 02:04 AM)Boern Wrote: This also adds squeekboard 1.9.1
1.9.1-pre is an arbitraty version number I chose actually, please keep in mind this isn't an official release Wink
It has support for modifier keys however, which is indeed a nice much-needed feature.
(04-28-2020, 02:04 AM)Boern Wrote: I hope it also enabled tweaking the height of the keyboard
Nope, this is still WIP upstream, with no clear timeline at the moment.
(04-28-2020, 08:02 AM)dukla2000 Wrote: Another benefit of 1.8 over 2 is 5 icons in the favourites line Cool
Yup, I like this one too! Also, not having to scroll for the last apps is fine Smile
(04-28-2020, 08:02 AM)dukla2000 Wrote: WiFi hotspot sharing is pretty reliable now - I have tried to put instructions here in the wiki.
Awesome, thanks! I'll try to include that in the next release Smile
(04-28-2020, 08:02 AM)dukla2000 Wrote: b) Even adding an dhcp-range 10.0.0.50,10.0.0.150 I cant get internet sharing to work via the USB port!
Did you disable the "hardcoded" config first ? (assuming you have pinephone-devtools installed, it is stored in /etc/NetworkManager/system-connections/USB-gadget.nmconnection)
  Mobian image for the PinePhone Korfou 2 1,649 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 67,095 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 72,678 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 341,922 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,129 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,787 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,390 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,436 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,550 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 9,832 01-08-2024, 02:50 PM
Last Post: ERPlegend
Users browsing this thread: 7 Guest(s)
