Anyone have any luck getting snaps or scrcpy working
I'm wanting to install scrcpy and it's not available in Synaptic. It is available in snap packages and both show installed but when I go to run either I get command not found.
Any ideas or is it a situation where snaps dont work with arm processors?
(04-11-2020, 09:17 PM)MIchael Wrote: I'm wanting to install scrcpy and it's not available in Synaptic. It is available in snap packages and both show installed but when I go to run either I get command not found.
scrcpy is available in Debian Unstable repositories, if you're willing to try switching from the stock Debian/MATE (I assume that's what you're currently using?) to using unofficial Debian installer by danielt@. Alternatively, if you're adventurous enough and don't care about FDE, you can try upgrading, but if it breaks you get to keep both pieces.
This message was created with 100% recycled electrons
(04-18-2020, 09:44 AM)moonwalkers Wrote: scrcpy is available in Debian Unstable repositories, if you're willing to try switching from the stock Debian/MATE (I assume that's what you're currently using?) to using unofficial Debian installer by danielt@. Alternatively, if you're adventurous enough and don't care about FDE, you can try upgrading, but if it breaks you get to keep both pieces.
Yeah, I'm using stock Debian. I've got it set up and and working almost exactly like I want it. If Netflix breaks again I'll give your suggestion a try for sure.
  Slackware Linux working on PBP vxzero 0 3,353 06-05-2024, 04:30 PM
Last Post: vxzero
  USB 3 port not working with Armbian zaius 3 5,237 11-13-2023, 01:54 PM
Last Post: zaius
  Camera not working with Cheese cypresstwist 1 4,844 08-18-2023, 02:02 AM
Last Post: juliamenendez
  5GHz wifi not working snorwood 11 16,502 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 3,498 11-30-2022, 06:30 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 5,261 10-31-2022, 10:14 AM
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 3,215 09-30-2022, 10:09 AM
Last Post: crazyquark
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 7,170 08-25-2022, 02:15 PM
Last Post: Niko
Bug Pinebook Pro NVME stopped working secretagentdude 4 10,453 12-17-2021, 06:23 PM
Last Post: pinemouth
  Working suspend on Manjaro brzegorz 3 9,413 12-03-2021, 01:39 PM
Last Post: rik-shaw
