Flash dhivael's SPI uboot (risky)
#51
@LostZimbo that's good to hear Smile
#52
Quote:Note: This uboot binary was built for SPI environment only. It will not work if you try putting it on your eMMC.
What makes this build different compared to a uboot for the eMMC and are there instructions for building it myself? I'm trying to make my pinebook pro as blob-free as possible, and downloading an unsigned blob from some forum is pretty much the opposite of that :-D . I've already built uboot from https://eno.space/blog/2020/01/pbp-uboot and I use it successfully on my sd card, so I'm mostly looking for whats different for an SPI build.
Edit: Found a post on another thread mentioning the build instructions are in the git log, so nevermind.
  How to rewrite uboot to emmc pineitup 5 15,736 12-27-2020, 10:35 AM
Last Post: nightranger73
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 5,522 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 6,804 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 34,086 09-13-2020, 01:20 PM
Last Post: hmuller
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 89,003 07-28-2020, 03:18 PM
Last Post: SamWilts
  How to boot Manjaro from NVME with uboot on eMMC as400 47 100,707 06-07-2020, 02:37 AM
Last Post: as400
  (almost) upstream uboot/atf User 15997 27 55,586 02-08-2020, 10:18 PM
Last Post: Natrox
  Widevine-flash on Chromium-SD Card mamboman777 3 10,690 01-20-2020, 04:00 PM
