Best Solution to run a TvHeadend on Rock64?
Didn't need hauppauge support myself. My driver hadn't been back ported in the kernel I was using so using the PPA from Brad Love's GitHub did the trick. Just letting the OP know what to look out for.
@tophneal
@Rocklobster
This could work for DVB-S2:
https://www.linuxtv.org/wiki/index.php/P...ick_(461e)
@Tetterl It absolutely could! I almost posted a link to the LinuxTV wiki page for supported devices, but it hasn't been kept up and all the devices listed on the page were relics by now. There are far more supported USB tuners than given.
The OP should find all the driver and firmware support he needs here. Brad Love is active and only too glad to help https://github.com/b-rad-NDi/Ubuntu-medi...el-builder
I try to install:
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.8.3]
When I start the Rock64 there is no desktop.
Kind of Terminal.
I put in User/Password both rock64, but it stays in Terminal.
Is ther any command to go to desktop?
Is this a bug, what can I do?
Then I tried:
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.8.3]
But this started with Debian! Funny.
What is my mistake?
Where do I find a working Version of Ubuntu minimal or Desktop??
Thanks again!
Update:
Image I found on:
https://wiki.pine64.org/index.php/ROCK64
was this:
bionic-minimal-rock64-0.8.3-1141-arm64
Possible too old, is the Wiki Version old?
Now I download from github:
bionic-minimal-rock64-0.9.14-1159-arm64
Hope this will work.
"minimal" means no desktop ...
You can try some images from https://dl.armbian.com/rock64/archive/
@martinayotte
Thank you.
Then minimal is too minimal for me.
I will take:
bionic-lxde-rock64-0.9.14-1159-armhf.img.xz
Do you want your Rock64 with TV Headend to run as a server only or are you wanting a front end to work on it too. If its purely a server minimal will do fine
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,239 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,138 11-03-2025, 09:25 AM
Last Post: darkfader
  Rock64 - not booting after Armbian update helpmerock 6 3,916 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,464 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,604 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,701 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 72,299 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 101,765 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,769 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,719 12-27-2023, 10:34 AM
Last Post: dstallmo
