02-27-2020, 04:12 PM
Good job. The interface is more responsive than pmOS. I surely prefer it to pmOs
02-28-2020, 03:09 AM
I tested the new build leaving the phone idle overnight with WiFi and modem on. It lasted all night. The only thing is not working are the calls
Just installed XFCe. I like it more and now it's look more like Linux Phone The only issue --- no keyboard at the moment
02-28-2020, 05:27 AM
(02-28-2020, 04:23 AM)harvey186 Wrote: Just installed XFCe. I like it more and now it's look more like Linux Phone Cool! Here come the follow up questions =) Which packages did you install? How did you boot in to xfce?
"- is there already a tool for overclocking it desperately?"
(02-28-2020, 05:27 AM)murak Wrote: Which packages did you install? --> I have used 'sudo apt install task-xfce-desktop'
02-28-2020, 02:29 PM
For anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
https://www.youtube.com/watch?v=6YoNuJN3Z-A
02-28-2020, 05:56 PM
(02-28-2020, 04:23 AM)harvey186 Wrote: Just installed XFCe. I like it more and now it's look more like Linux PhoneCool ![]() But just so you know, starting from the next release, there will be no display manager, you'll have to install gdm3 as well (or lightdm, should work too) (02-28-2020, 09:34 AM)nas Wrote: It appears a voltage patch needs to be applied to prevent the lcd being fried. Hopefully, the next image version will have this baked in?Yep, I've just uploaded a new kernel including this fix, you're an "apt upgrade" away from it
02-29-2020, 03:00 AM
parkerwbFor anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
But that's not a PinePhone in the video, or ??
02-29-2020, 05:03 AM
is there a difference between 'sudo apt update' and using a the latest (new) image ? Because with new image a lost all my working apps.
02-29-2020, 06:42 AM
There are a couple differences, but nothing really huge... You'll probably have to manually uninstall gdm3, but that's pretty much all
I should do a bunch of metapackages to make things better when I have some spare time. |
