Howto: Mobile data on pmOS + Phosh with APN requiring user/pass
Star
Have been having trouble getting mobile data on any of the available distributions, and finally with the help of IRC, manpages, and a few guides, I managed to get mobile data on my operator, which requires setting up an APN with user and password.
So for me it wasn't a simple matter of using ofonoctl wan --connect --append-dns, or simply enabling ofonod, or anything of the sorts. I had to dig in deeper.
This has only been tested under pmOS + Phosh so far, because it uses NetworkManager and it's easy to install ModemManager without messing up the whole system (like I did once under Ubuntu Touch). YMMV on other distributions.
Step 1
Install pmOS your favorite way, and make sure to install modemmanager
apk add modemmanager
Step 2
Disable ofono, enable modemmanager at startup
As root:
rc-service ofono stop
rc-update del ofono
rc-update del ofono-auto-enable
rc-update add modemmanager
rc-service modemmanger start
Step 3
Wait 10-20 seconds and check the status of your modem with:
mmcli -L
mmcli -m 0
If all is good, you can also see the 4G and modem icons in the status bar.
Step 4
Create a "bearer"
mmcli -m 0 --create-bearer='apn=APN.NAME,user=USERNAME,password=PASSWORD,allowed-auth=chap,allow-roaming=no'
auth and roaming may vary on your provider.
Once you've done the above successfully, you should see a new device in network manager (previously it was alled ttyUSB2) : cdc-wdm0
This is the device name to use in the next step
Step 5
Now configure the connection with nmcli, I'm not sure if you need to specify tall the APN info all over again or not, I'll have to try without and update this guide:
nmcli c add type gsm ifname cdc-wdm0 con-name OPERATOR-NAME apn APN.NAME user USERNAME password PASSWORD
Step 6
Verify connectivity with all the usual commands
nmcli c   # check status of the connection named OPERATOR-NAME as above
nmcli d    #  check status of cdc-wdm0
ip addr   # check for wwan0
and so on.
References:
https://docs.ubuntu.com/core/en/stacks/n...onnections
https://www.freedesktop.org/software/Mod...cli.8.html
I hear that ofono would be needed for phonecalls (which my SIM can't do), so YMMV...
(02-28-2020, 09:06 PM)pajux Wrote: I hear that ofono would be needed for phonecalls (which my SIM can't do), so YMMV...
Nope, you don't need ofono for voice calls. ModemManager handles them just fine. You need something to handle routing the audio when calls are answered. The PureOS PinePhone image only has ModemManager installed and works with calls, sms and data.
Good to know, awesome!
  more mobile linux on reddit(thank Goog for signed APKs) biketool 2 8,503 09-08-2025, 12:03 PM
  beta release of a Linux mobile app strength training app coryholl 1 2,837 08-29-2025, 06:06 PM
Last Post: coryholl
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 19,695 07-18-2025, 04:24 PM
Last Post: dchang0
  Public Mobile (Canada): failure to configure VoLTE digdis 6 3,345 07-14-2025, 04:17 PM
Last Post: digdis
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 8,686 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 5,631 12-13-2023, 01:24 AM
Last Post: oldschool
  how to backup user data? Uturn 1 2,052 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 5,670 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 7,483 06-30-2023, 11:39 PM
Last Post: ionmich
  Can't get through "User Configuration" on new PinePhone a-l 24 31,559 06-01-2023, 10:08 AM
Last Post: feketej
