Armbian for Rock64
(01-30-2020, 08:23 PM)janke Wrote:
(06-19-2018, 02:35 AM)pineadmin Wrote: Added Armbian Debian Stretch Desktop (ROCK64) 5.42 on Wiki and PINE64 Installer.
Added Armbian Ubuntu Xenial  (ROCK64) 5.42 on Wiki and PINE64 Installer.
Hi pineadmin:
I have several questions to ask:
1. For rock64, how to distinguish V2 or V3?
2. How do I burn the armbian Linux image to EMMC? It seems that can't use Android tool.exe, right? No relevant information can be found everywhere. Please give me some advice!
For #1 are you asking how to look at a board and know what it is?
I have a ver 2 board and it states ver 2 in text on the top/front above the SoC. If you look at this https://store.pine64.org/?product=rock64...d-computer picture you can see this was says ver 1.
Hi pineadmin:
I have a version 1 board. Anything made for version 2 will work for version 1. I'm not so certain about version 3 on version 1.
If you buy a Rock64 new from Pine, your getting a version 3. If you bought one in the last year or so, probably a version 3.
Bought one in mid to late 2018, probably version 2.
Bought one in mid 2017 to early 2018, probably a version 1, possibly a version 2 if you bought it later than earlier.
Hi pineadmin:
Thanks! I saw the V2 logo on the board, and I can confirm that my board is V2! Thank you again!
Hi pineadmin:
Thanks your reply,but,i want to know:
Hi pineadmin:
It has been a long time since I ran Armbian but I'm pretty certain Armbian had a config that allows you to transfer a working SD boot to EMMC. This works if you do NOT have an EMMC to USB module.
Setup Armbian on SD with balenaEtcher. Insert it into your Rock64 and boot from SD card WITH the EMMC module plugged into the Rock64 as well. Run armbian-config. There's an option to transfer everything to EMMC. Your next boot will transfer, automatically reboot to EMMC, and boot from EMMC.
If you have an EMMC to USB adapter (Pine64 store sells one cheap!) then you can use balenaEtcher just as you would a SD card. Plug it into your Rock64 after balenaEtcher is done and boot. That's all.
You can also use directly the "nand-sata-install" script ...
I've got a v2 and I'm outta luck on anything but old Armbian rock64 4.4 images. No 5.4.x or RC's will boot. Just FYI for other would be owners.
(01-30-2020, 08:23 PM)janke Wrote: Hi pineadmin:
Thanks again very much!
Now all I know about rock64 is from the forum and online search. Is there a complete document to learn about rock64? For example, I now use the sdcard to start the board. Diept can't detect EMMC. What should I do? There are many operating systems supported by rock64. For each system supporting EMMC, how to write the system to EMMC and where can I find it? For these problems, rock64 officials should provide relevant information. Thank you again for your support!
(02-01-2020, 02:50 AM)clach04 Wrote: For #1 are you asking how to look at a board and know what it is?
Do you own one of these? https://store.pine64.org/?product=usb-ad...mmc-module
If yes, plug your EMMC into that and plug it into a USB port on your computer. Format it any filesystem. Download balenaEtcher: https://www.balena.io/etcher/
Use that to burn any EMMC compatible operating system to the EMMC. Plug the EMMC into your Rock64. Boot.
If you DONT have one of those adapters, it gets harder. But, this should do the job just fine: https://forum.pine64.org/showthread.php?tid=4924
(02-01-2020, 07:36 AM)dudemo Wrote: I have a version 1 board. Anything made for version 2 will work for version 1. I'm not so certain about version 3 on version 1.
Thank you again for your patience reply. I have got all relevant information. now, i dont't have USB burner. Moreover,i'm  in China, USB burners are not easy to buy. Therefore, I can only try it in another way first. Thank you!
  Raudio for Rock64 V2 shinzuka 3 396 05-20-2026, 02:02 PM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,908 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 780 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,424 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,319 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,918 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,109 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,232 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 83,741 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 108,324 09-01-2024, 06:05 AM
