Potential Battery Failure
I've had the Pinebook Pro for a few months now, and it's been perfectly fine until this afternoon. I was using it earlier this morning, plugged in with the barrel jack at 10% charge, to watch YouTube on the default OS. I left it to charge for a few hours (again, with the barrel jack) and when I came back the computer had zero charge. It will boot when plugged in, but of course shuts down when power is removed. I opened up the device and nothing appears out of the ordinary.
what happens if you use USB-C pd?
you could also bypass the battery and plug the barrel jack and turn on to test the main board is functional as intended. I would operate at low brightness.
highlights the possible need for replacement batteries in the store!
I would try making sure your PBP is fully shut down, then charge for a while (10 hours) and see where you're at. Suspend has been a bit problematic on mine. When I close the lid it suspends, but plugging in the power cord triggers a wake.
It seems to be working ok now, I don't know what went wrong. To be clear, it's only been working after using my usb-c charger. It's possible I was using the wrong barrel charger maybe? It was rated for 5V 3A.
  Pinebook Pro drains ny battery after shutting it off Tongman 4 5,197 12-01-2022, 02:50 AM
  Battery Frost1776 1 2,355 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 5,771 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 5,410 09-09-2022, 08:13 PM
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 3,413 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Very low battery (but charging) causes boot failures Phillip Bell 7 8,440 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 8,559 02-10-2022, 11:52 AM
  NVMe SSD and battery life? dieselnutjob 3 5,989 04-19-2021, 01:55 PM
Last Post: slyecho
  [AUG 2020] PBP Battery Issue (?) mercato 7 11,382 09-22-2020, 12:10 AM
  No battery or wifi after poweroff Goin2mars 3 6,620 09-19-2020, 09:58 AM
Last Post: xmixahlx
